Question about iLO 3200 32 in. LCD Television
TV won't come on, it just stays in standby mode The red led just blinks when you try to turn it on and hear a little whistling noise if you listen closely. I was thinking it could be a power supply issue but don't know. Help please
  • iLO Master
  • 19,396 Answers
Hi.
The TV staying in standby and the light flashing indicates that the TV is in fault mode (often called protect mode). This happens when an internal fault is detected, and the main board set the unit in forced stand-by with the led color changing.
Before doing anything else try disconnecting TV from power for ten minutes. Restart the TV with no device connected, leave it on for a while and see how it goes. Test the TV with different devices (eg. DVD, VHS,sat box, console etc .)
In your case it looks like there is no clear indication toward a particular fault. The TV coming on at random times, may point at a defective PSU, but other failures such as defective main board, overheating, defective inverter, or faulty Timing controller (TCon) may result in the same problem.
The most common fault that may cause the symptom you described is PSU. Unless there is clear sign that the PSU is damaged, this is still far from being enough to decide that PSU is the culprit. The power supply must be tested before replacing parts. Testing is done reading PSU out on different voltages. This is an operation that must be done by a trained repairer.
The high pitched noise may be given by a defective PSU capacitor. In that case the bulged or leaking capacitor is usually easy to spot looking directly at the PSU.
To book a repair call the manufacturer at the number listed on the owners manual.
To get part price, enter model here: ShopJimmy.
Regards.
Ginko.
Posted on Feb 19, 2011
2 Suggested Answers
6ya staff
SOURCE:
SOURCE: MY ILO LCT27HA36 TV won't come on, it just stays in standby mode/
Just FYI, I have fixed 3 of them and on all 3 of them it was the capacitors on the power board. The capacitors I changed on all 3 I got at mouser.com. They were: (3)-1000uf 16v PT#667-EEU-FC1C102, (2)-470uf 35v PT#667-EEU-FC1V471, (2)-1000uf 35v PT#667-EEU-FC1V102, and (2)-220uf 25v PT#667-ECA-1EHG221 the last two are located under a heat sink that you have to remove to replace them. The cost was around $15.00 with shipping for them. This is all I had to change on the ones I fixed but yours may not be the same i would not know without looking at it. Good luck and I hope it all works out for you all as it did for me. If it works for you feel free to contact me and say thank you at thanks@robbob.net
Posted on Oct 13, 2011
Samsung LED 60' TV UN60J620DAFXZA not turning on? No red standby light? No backlights?
Did you try repairing the PS with a repair kit first then replace both the boards after that?
Nov 10, 2017 | Samsung Televison & Video
I have a Neon c2297f. When I plug it in and turn on the power, the red LED blinks, whenever the LED blinks on I hear a discharge from the speakers.
Those blinks [flashes] are fault indication (Error Codes). From the number of blinks occur at one time switch ON, you can get an idea about the faulty circuit section inside it. This will make repair easy. These are called blinking codes. Make sure about the exact number of blinking of the standby/power LED, by switching On & OFF the set, for at least two times. Count it carefully. If you wish to get some details, check the site linked here. It has details about blinking codes, and fault locating procedure, to many popular brand TVs and other devices.
http://homenol.blogspot.com/
If blinks continue without any pause, the main board is faulty.
Aug 15, 2017 | Televison & Video
Sony Triniton TV KV 32FS120 will not turn on
In standby mode (red led on/after the led stops from blinking), press "Display", "5", Volume (-)", "Power on" on the remote control in sequence, self diagnostic screen will be display, let me know the what is on the screen to diagnose where the fault came from.
Nov 25, 2011 | Sony FD Trinitron WEGA KV-32FS120 32" TV
Tele turned itself off, red light blinks 4 times then pauses and blinks 4 times again.
You can try unplugging it for a while and then plugging it back in, but according to the manual, the standby LED:
Lights up red when your TV is in PC power saving mode. If the LED blinks in red continuously, this may indicate the TV needs servicing.
(Operating Instructions, Page 22)
Mar 05, 2011 | Sony BRAVIA KDL-32S2000 32 in. LCD HDTV
KV-36XBR400 won't turn on, "standby/stero" light
You are correct. You are right about the power supply and replacing with led hdtv. You will be happy with a Samsung led. Time to upgrade.
Mar 04, 2011 | Sony KV-36XBR400 36" TV
LED blinking red
A red blinking light usually means the system is in standby mode.when you press power or TV it should turn on and be green. Try manually turning set on or off.
Jan 04, 2011 | RCA F38310 38" TV
I have power but it will not turn on. unplugged from power cord overnight then plugged into wall worked fine until i shut it off again, now it keeps blinking the delay light
go to turn tv on,hear a poping noise,once then tv standby lite blinks 3 times repeatily but no picture or audio.can you help me out with this thank you
Feb 14, 2010 | Sony FD Trinitron WEGA KV-36HS510 36" TV
STANDBY LIGHT TURN ON
when turning on the set will go three startup cycles about 2-3 min. then all three leds will blink/ possible causes /lamp/ballast/dmd board check or purchase the dmd board last (costs) also listen for arcing from the ballest at startup and fan noise if you can and color wheel noise also.if you hear the ballast arcing and trying to fire the lamp look at the lamp.
Jun 15, 2008 | Samsung DLP HL-P5663W 56" TV
iLO 3200 32 in. LCD Television Logo
1,020 people viewed this question
Top iLO Televison & Video Experts
Ekse
Jerry Greenberg
Jerry Greenberg
matt martin
matt martin
Are you an iLO Televison and Video Expert? Answer questions, earn points and help others
