Question about Tally Dot Matrix T2265C Printer
T2265+ Printer with hardware alarm, +0355 +131 - -- 0000003+0377+0387
    New Friend:
Clean the carriage film " dust "
Posted on Mar 31, 2012
    New Friend:
  • 17 Answers
Your carraige motor is bad. 0000003 means 1 Horiz task active andMotor accell. Bad carriage motor.
Task Control Code Meaning / Description
1 Horizontal Task - active
2 Horizontal Task - Motor is accelerating
4 Horizontal Task - Motor Break on
8 Vertical Movement - active
16 Color Motor - active
32 Motor Function Select - active
64 Motor Sheetfeeder - active
128 Adjustment Printhead Clearance - active
128 B Adjustment AGA
- shift the horizontal drive belt
one notch to the right and
fasten belt again according
adjustments 6.1.1 - active
256 Paper Feed Sheetfeeder - active
512 Bell (sound) - active
1024 Shiftmagnet Printhead - active
2048 Papermovement - active
4096 Tear / View from ESC Seq. - active
8192 Paper Load - active
16384 Paper Eject - active
32768 Tear or View (general) - active
Posted on Feb 17, 2011
2 Suggested Answers
6ya staff
SOURCE:
Anonymous
SOURCE: please help
I am already faced this problem, This Problem is due to Bad Head cable. Repaced that cable, your Problem will be resolved
Posted on Nov 24, 2008
My printer is showing error as "hardware alarm +1308 +131 --- 000004+0381+1317" wat could be the problem
The hardware error indicated on your printer is indicating that the printer is encountering problems when moving the print head.
This error can be indicated if there is any thing which may be preventing print head movement, things you can check include;
The printer ribbon is not jammed and is located correctly in the printer,
You can also check to ensure there is no paper jam of loose paper which may prevent print head movement,
You can also check the carriage shaft to ensure it is free from paper dust or any other obstructions.
With the printer powered off, the print head should slide freely across the width of the printer, you can then see if there is any obstruction to the printhead
Nov 18, 2011 | Tally Matrix T2280 Printer
Hi There. I have Tally T2265 Serial Matrix Printer. It shows "Hardware Alarm & Check Ribbon Error" after printing 2 or 3 pages. Sometime it prints 7-8 pages and sometime it prints 2-3lines...
The check ribbon message on the 2265 indicates the printer is detecting problems with moving the print head. You have ruled out the ribbon as being the cause of the problem by using ribbons from another printer.
Before suspecting other components check the printer model, if the printer is a 2265+ check to ensure the correct ribbon is used. Note the ribbon for the 2265+ is different to the 2265 ribbon. The 2265+ has a ribbon sensor to detect the ribbon moving. If the printer is a 2265+ the part number for the ribbon should be 062471.
If the correct ribbon is used the problem could be the timing strip which could be dirty or warn. Try cleaning this and check for damage.
The problem can also be caused by a dirty or lubricated carriage shaft, the carriage shaft should be clean and dry running - Keep clean of any type of lubricant.
The problem can also be caused by the timing station on the carriage, the carriage motor.
Mar 10, 2011 | TallyGenicom 2280 Matrix Printer
Hardware alarm 0036 131 000004 0376 0009 hardware alarm 0025 131 000004 0376 0009 hardware alarm 0024 131 000004 0376 0009
Hi, the printer seems to have a problem with the horizontal movement of the print head carriage. Turn of the printer and move the carriage by hand to check if there is an area where it can only be moved too hard. If yes, clean the carriage shaft from dirt, etc.
Sep 08, 2010 | TallyGenicom 2265+ Matrix Printer
Our tally 2280 Dot matrix has an alarm code 025609413032 What causes this to be displayed on the 2280 screen.?
check out this FAQ page for the hardware alarm codes:
http://support.dascomeurope.com/index.php?option=com_content&view=article&id=295%3Ahardware-alarms&catid=234%3Afaqs-t2265-t2280&Itemid=57&lang=en
Mar 19, 2010 | TallyGenicom 2280 Matrix Printer
Tally t2265 'check ribbon' hardware alarm... carriage moves ok, 2 new ribbons ...that came from other machines,,,, ribbon drive seems fine, could it be encoder strip??? please help!
Befor suspecting other components check the pritner model, if the printer is a 2265+ check to ensure the correct ribbon is used. Note the ribbon for the 2265+ is different to the 2265 ribbon. The 2265+ has a ribbon sensor to detect the ribbon moving. If the printer is a 2265+ the part number for the ribon should be 062471.
If the correct ribbon is used the problem could be the timming strip which could be dirty or warn. Try cleaning this and check for damage.
The problem can also be cused by the timing station on the carraige, the carriage motor.
Jul 03, 2009 | TallyGenicom 2280 Matrix Printer
Tally printer hardware alarm home postion
There is a broken gear(s) in its mechanism that's why you are having this hardware alarm message.
Dec 07, 2008 | Tally T2250 Matrix Printer
I have a tally t2265. when i switch it on it comes up with "hardware error". Please help Don
9 out of 10 times this error is caused by the print head assembly binding up on the platen (the metal bar that the print head moves back and forth on). Remove the ribbon and paper from the printer. Wrap a thin cloth or Kimwipe around the platen and spay some WD-40 on the cloth. Work the cloth back and forth on the platen to clean it. Then with the platen still damp with WD-40 work the print head assembly from side to side, this will clean out the inside of the print head assembly. Clean the platen one more time.
I have seen this problem caused by two other things, a defective ribbon casette or worn out drive gears.
Dec 01, 2008 | TallyGenicom (048959) for T2265, T2280,...
Please help
Aug 20, 2008 | Tally Dot Matrix T2265C Printer
Tally Dot Matrix T2265C Printer Logo
1,219 people viewed this question
Top Tally Office Equipment & Supplies Experts
Thomas F. Schneider
Zaid Anarwala
Zaid Anarwala
CheckitRight
CheckitRight
Are you a Tally Office Equipment and Supply Expert? Answer questions, earn points and help others
