Make sure you are threading the machine correctly. Make sure you are using serger thread that isn't old. Make sure you are undoing all the threads when it breaks and thread it from the beginning.
Make sure you have the right needles in their respective places. My Juki MO has two different size needles.
make sure the top tension is not to tight keep longer thread tails for 4 to 7 inches keep the thread pulled behind the needle before you start sewing see if that helps solve the problem
I also have the Juki M)-655. Look at the power button; it should have 3 positions. First position turns the power switch Off, second position turns the power switch on and it will sew, third position turns on both the power switch and the sewing light. Several times I have thought I turned on the power switch to sew only to realize it was not in the second position. Hope this helps.
How to Thread Juki MO-134 Serger from watching lady at Lyles.
Turn upper blade up. Push in first then turn up.It makes threading easier.
Blue Thread upper looper first.
Pull thread through tension knob. Don'tjust lay it there. (She thought that is what I must have done)
Orange Thread lower looper next.
Pull thread through tension knob as inthreading upper looper.
Adjust lower looper so it is right nextto upper looper so that their points are almost together and directly belowsewing needles. Lower looper will be in front of upper looper (I believe).
With tread from upper looper pulledback, slightly lift lower looper above upper looper and thread. I think this isright.
Pull thread back with other thread.
Tension is the key. Remember that.
Yellow: Thread left needle first.Remember tension. Pull thread through curled wire on left side of needle arm.
Green: Thread right needle. Rememberabout tension. Pull thread through curled wire on right side of needle arm.
b>
Note: Before sewing turn the wheel tomake sure the stitches are going together correctly.
Normal
0
MicrosoftInternetExplorer4
/* Style Definitions */
table.MsoNormalTable
{mso-style-name:"Table Normal";
mso-tstyle-rowband-size:0;
mso-tstyle-colband-size:0;
mso-style-noshow:yes;
mso-style-parent:"";
mso-padding-alt:0in 5.4pt 0in 5.4pt;
mso-para-margin:0in;
mso-para-margin-bottom:.0001pt;
mso-pagination:widow-orphan;
font-size:10.0pt;
font-family:"Times New Roman";}
all machines thread the same. TTN tension,take up,needle.
Beginning with the spool, guide the
thread through the thread guides to the tension assembly. Pull the thread
through the tension assembly and test it to make sure the tension is working
correctly.
(To do this test, adjust your tension setting to normal or medium or 5 or
something in the middle. Raise the presser foot and pull the thread through the
tension. It should pull easily!! Lower the presser foot and pull the thread. It
should pull noticeably harder.) If it passes this test, continue up through the
take up lever,then down through the thread guides to the needle. Make sure your
needle is fully inserted and turned the correct way.( If you load your bobbin
case from the left side,the needle rule is normally FLAT to the RIGHT is RIGHT.
There are some exceptions. If you have a newer style drop in bobbin or your
bobbin case loads in the front then the rule is FLAT to the BACK.
