Washing Machines Logo
Posted on Feb 02, 2011
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
When i try to start the washer code d5 shows ands chimes
Anonymous
Level 3:
Brigadier General:
  • Master 3,513 Answers
  • Posted on Feb 02, 2011
Anonymous
Master
Level 3:
Brigadier General:
Answers
3513
Questions
0
Helped
867857
Points
10095
Hi
The reason for d5 error is due to defective door lock switch. It is a door lock error code, more than likely a bad door latch it's an easy repair. When washer displays this code it means door is open while washer is running. Check the lid switch and striker.
Please get back to us if you have further query else please accept the suggestion.
Thank you for contacting fixya.com
21helpful
D5 error
Error code D5 OR DS is the same.Its mostly DS which looks like D5. The D5 error is actually DS. The code means the washer thinks the door is open or unlocked during the cycle. The door has to be checked.Is it getting properly close/open.If its getting close/open then the problem is related to faulty door locking assembly. But if its not getting proper close then there is any blockage causing the door to close or the door lock latch is faulty causing this problem.
Hope helps.
1helpful
GE Profile washer shows d5 how do I eliminate that so I can wash
Hi and welcome to FixYa, I am Kelly.
D5 is a lid switch error. It comes on when there are 3 complete cycles without a lid switch actuation. Either the lid switch has failed or something is causing the lid switch to not sense lid movement. This is a proximity type switch that uses a magnet to actuate the switch. Check to see that both the switch is in place and that the lid itself is not loose at the hinge or shifted to one side.
The lid switch is item 90 of this link:
http://www.appliancepartspros.com/partsearch/model.aspx?model_id=5130746
http://www.appliancepartspros.com/part_details.aspx?part_id=3204102
You can try to unplug it for 6 minutes and plug it back in again to clear the code but if the lid switch is bad you will get the D5 code again. Not only that if you have children around it is not safe to leave the washer un-attended with a bad switch because the machine will not stop spinning in the spin cycle with a bad switch. If they lift the lid and stick their hands inside the end result can be quite horrific.
Thanks for choosing FixYa,
Kelly
11helpful
When i turn it on it beeps and the letters d5 show up
hello,
this indication is an error code saying that the door of the washer is not well luck /close
what you are to do to solve the problem is to put off the washer from the power supply then on it again after some time then open then door and close it properly with care the d5 code will be solve
thank you and thanks for using fixya.
1helpful
What does code d5 mean? The machine will stop and stay idle for several minutes and then start again. This happens several times per load, but eventually finishes.
Hi, The reason for d5 error is due to defective door lock switch. You will need to have this damaged mechanism replaced to fix this problem.
1helpful
Display showing d5?
d5 - door is open when washer is running.
or the door switch is bad.
Power out when running. showed code F 71 now not working.
After power outage that will happen do this to fix.
Select PAUSE/CANCEL twice to cancel the cycle. Select
DRAIN & SPIN if there is excessive water in the washer.
Re-select cycle and press START. If the problem remains, call
for service.
Whirlpool duet f21 and d5 codes
You have me there, my book I learned from doesn't show any d codes.
Top Washing Machines Experts
john h
