SOURCE: attaching computer to tv after load, screen goes
it sound like you need to check your instruction book for the compatibility setting between the monitor and computer. see if your monitor has an auto feature, if so press it with the computer hooked up to it. this is if you are using the 15pin hd connection. otherwise it could be a setting on your menu of the monitor to change the refresh rate.
SOURCE: How do I format a video. When I down load it say
Most players will now use a mp4 type of video. You can use a program called "Any Video Converter" see link below..--->>> http://www8.any-video-converter.com/products/for_video_free/ <<---
Copy and paste into a new tab or window. Use this program to convert the video you want to put on your player,
you may have to adjust the settings but I use it it works for me.
