Westinghouse LTV-32w1 32 in. HD-Ready LCD Television Logo
Posted on Feb 02, 2011
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
I just bought a new LD 325 TV I am very disappointed with the capabilities of the remote, It only seems to work if you are standing directly in front of the TV.Is there any fix for this problem or should i take it back and get another brand
Bud Martin
Level 3:
  • Master 11,361 Answers
  • Posted on Feb 02, 2011
Bud Martin
Master
Level 3:
Answers
11361
Questions
Helped
3366078
Points
33650
I would take the remote that you have and try it on the TV in the store where you bought the TV from to see if it does the same thing, if it does, then it is just a poorly design TV.
Please leave rating if it helps.
2answers
Cual es el codigo de acceso para canales de tv LD-2240
C?digo de acceso para tv westinghouse, modelo LD-2240 , num de serie :6610120103391
I am shipping my tv to my new location, need to know the weight
Which model TV do you have?
The TVs in the LD-325 line are 14.55 pounds with the stand, but is 13.45 lbs without. If you have the original shipping container and all the accessories, the LD-3255VX weighed 21.83 lbs. The LD-3255AR is 23.2 lbs in the box.
The EW32S3PW with the stand is 15 pounds and 1.5 pounds lighter without the stand.
The older model SK-32H640G is 23.9 pounds with the stand. Removing the stand takes 1.4 lbs off the TV weight. When in the original box with accessories, the TV weighed 27.0 pounds.
There are a number of other models, so please add a comment with the model number and if the stand and accessories are going to be in the same box. I hope this gives you some help.
2helpful
My Westinghouse LD-325 series LED TV will not shut off/on with the side button but it will respond to the remote OR by pressing the top two button at the same time. By pressing the top two buttons (m
one or more of the tiny switches on that board with the controls is bad--either replace the board with the controls or just use the remote.
The plastic buttons will seem fine--it is the tiny switches under them that causes this issue.
WESTINGHOUSE LD-4655VX CODE FOR XFINITY REMOTE
The Westinghouse LD-4655VX TV has code compatibility with Sony TVs (http://westinghouseelectronics.com/wp-content/uploads/2012/06/Remote_Codes_2012.pdf). I accidentally discovered that the Sony TV remote RM-YD040 works with my he Westinghouse LD-4655VX (because I have both TV sets).
I have Verizon FIOS for my cable - I just bought an Insignia TV and neither my FIOS nor Insignia remote control work on the new TV - how do I correct this situation.
The device is expected to have been acquired with a compartible remote control. However, a universal remote control is capable of powering the new TV only acquirable separatly at retail. Once acquired, the remote user guide provided the step by step instrucntions on acquiring transmittion signal from the new TV or very additional devices, sometime capable of being powered by once universal remote control.
I have a 1 1/2 year old dolby digital flat screen tv. The remote stopped working so i bought a new remote. It will not work either. Is there something I can do?
See if your remote will work when standing in front of the tv. Since you bought a new remote and it is not working either you may have a bad power sensor or board on the tv set. Is the new remote the exact replacement for your tv set? If not it may not be programmed correctly.
The remote has to be within 5 feet directly in front of the eye on the TV. It also will not work with the cable universal remote.
We have the same tv and the same issues. I've tried new batteries, it's been like this since we bought it. I also cannot find a code that will work with the tv on a universal remote or the direct tv remote. It's frustrating. Anyone else found a solution?
Remote control not working
If the new remote is not working either, it sounds as if the problem relates to the sensor on the TV combo.
If you bought it new last Xmas you should have some warranty left. I would get it looked at asap before the warranty expires.
Vizio, Model P4, manufactured in 2003 -- worked fine until 5 minutes ago
I have the same tv and the same problem. The power switch in the front flashes a bunch of times, but nothing else happens. Have you had any success in getting yours fixed?
Top Westinghouse Televison & Video Experts
Grand Canyon Tech
Grand Canyon Tech
Paul Bade
Are you a Westinghouse Televison and Video Expert? Answer questions, earn points and help others
