While moving, the equalizer slides / controls broke off . Where can you find them and are they replaceable? Crate Telluride Accoustic amp.
Yes, the pots are replaceable. Removing them from the circuit board requires solder removal tools. DO NOT atttempt to remove these with solder wick. The new high temp solder (ROHS) will surely cause the board to be damaged. I use an Ungar powered solder removal system. The parts can be found at DigiKey.com or Mouser.com. The part value is marked as is the taper which will likely be an "A" or "B" suffix. Search for potentiometer, slide. You have to exactly match the circuit board pin layout. The distributors have links to the manufacturer's spec sheets to compare. First thing is to measure the travel, then find ones with the right mounting, then the resistance and finally the taper suffix. The parts are typically between $1.50 and $3 each.
