SOURCE: Kyocera Ecosys FS-3900DN in HP emulation mode
Right click on the printer icon and choose properties. Your emulations are listed there.
SOURCE: CALL SERVICE 7410:0002988
the 7410 error may be a drum unit that is not pushed in properly or it could be the following
defective drum EEPROM drum needs to be replaced or
defective engine PCB
the above suggestions assume that it is an original Kyocera drum
hope it helps
SOURCE: I am getting Call Service 7410:00 32266 on FS-3900DN
push in the drum until you hear a click
SOURCE: What does mean Kyocera FS-3900DN Call Service 7410:0020192 ?
take out your paper tray... drum and developer and then pull out the paper
I’m happy to assist further over the phone at https://www.6ya.com/expert/norman_d2fa496dce30c65d
SOURCE: Kyocera FS-3900DN Ecosys Call Service 2200:0100998
The Call Service 2200 is a drum motor error. The motor or gears might need to be replaced. First remove and re-seat both the developer and the drum unit. The developer is directly under the toner cartridge - lift it up then out first, then open left side door remove the waste bin and press the button on the drum unit just above the waste bin pull the unit out (carefull not to touch the drum surface). Re-seat both units. If this does not work call in a Kyocera Tech.
