Sennheiser CX 400 Headphones Logo
A
Anonymous Posted on Feb 03, 2011
My earphones have stopped playing music. It just started in the left ear, now it doesnt play in either. Can this be fixed?
Anonymous
Level 2:
New Friend:
  • Expert 42 Answers
  • Posted on Feb 03, 2011
Anonymous
Expert
Level 2:
New Friend:
Answers
42
Questions
Helped
10350
Points
141
Try using other headphones to your unit, if it plays, the problem is in the CX400 indeed. usually caused by unintentional yanking & other factors, the internal of the wires were broken, it can be fixed yes, with patience and some soldering skills, just find the appropriate cable for that particular model, with imagination you can even use other headphone cables, ;-)
When I plug my headphones in why doesnt the sound come out of the headphones?
Where do you plug in the phones? if it is an iPhone. the music playing will be stopped, just to precent your ears to be damaged. When plugging in headphones, while the volume is high, the sound level can be so high, you can damage your ears. Yes damage that will last the set of your life, because loss of hearing, can't regenerate. For that reason some MP3 played, cill stop music playing, as soon as a headphone is plugged in.
Just start the music that was playing when you did lower he output volume if the music stops.
2answers
Headphone/earphones only left ear plays
Either the plus is not completely inserted (most likely) or a wire is loose or the earphones are damaged.
3answers
My phones' audio jack won't play music from the right ear bud
Have you use another headphones insteading of your Sony headphones to have a try? Make sure it is not the problem of headphone, then you may need a headphone jack replacement to replace the old one.
I've also met this situation with my phone. Finally I found the right
Headphone Earphone Audio Jack Flex Cable for Samsung Galaxy S4 i9500 to solve this problem. You can also look for one repair part for your phone, then find a video following to fix. It is easy to make it. Hope it can help.
1helpful
2answers
I plugged my earphones into my ipod and laptop to play music, and the music comes out of my left earphone, but not the right
This could the way the music is been recorded if it is strero or mono, also do confirm the earphone if one side of the earphone is faulty or not, if bad replace with the exact type and if not the media itself is faulty, you can take it the an electronics repair shop for them to diagonised the appliances... Hope this will help in solving.......
One of the ear buds on me ifrogz earpollution headphones just stopped playing music. I haven't been dragging them around or getting them wet or anything, and they're only a couple of months old. The other...
I had same problem. 1 of earphones stopped working. If i turn up volume, some sounds gets through, but then the other earphone would be blasting. Used them running so maybe sweat or earwax clogged them, but the problem didn't start until 1 month after stopped running.
2helpful
Down loads music that play on media player but won't play throught speaker and shows in file on sony it will not play out the earphones i did delete the music on the sony and put more on but it won't play...
Transfer mp3 files through Sonic Stage software in Sony NW-E307 mp3 player to get sound in its earphones
You can install Sonic Stage software from cd supplied with player or click Sony Support to download it by selecting OS in your computer in drop down list on that page.
2answers
Apple Ipod 4th Generation is only playing music through left ear jack. I'm confident it is a earphone/jack replacement issue. The problem occured when someone yanked my ipod from me and the ear bud cord...
Well, yes you are right there is no other issue than earphone. you can purchase the earphone from the below link -
http://cgi.ebay.com/ORIGINAL-Apple-4Gen-Earphones-Headphones-for-All-iPod_W0QQitemZ260523098037QQcmdZViewItemQQimsxZ20091214?IMSfp=TL091214234010r19836
Good Luck!!
Thanks
1helpful
2answers
My ipod crackles and my hearing seems to be getting damaged
Id say you should go see a doctor. But for now id say that you should do your best to not listen to it for a while as it can affect hearing. try to use full on speakers if you can. On you tube there are a few Sub-Woofer sound tests you can do. Try playing one (low volume) and repeat. (not a song one)
http://www.teenbuzz.org/ also to hear which frequencies are out of range to you click here. ( click the second icon on the list further down the page)
But yeah go see a doctor. Perhaps some ear drops.
4helpful
2answers
Motorola S9 headset plays music in one ear
I had the same problem with a Samsung phone. There are two ways of fixing this; First, you can remove the S9 profile from your phone's bluetooth list, and then add it again, going through pairing and entering 0000 on your phone when asked for the code.
Alternatively, you might try pressing the "play" button on the right earpiece on the Motorola S9. This is supposed to kick it into the A2DP stereo mode for music listening.
Good luck.
And get a copy of the manual from the Motorola web site at http://direct.motorola.com/ens/s9/Headset_Home.asp I found this very handy for checking what the little flashing lights mean. When you get stereo reception, the little LED in the middle of the headset flashes green, not the usual blue and red and purple for voice calls.
In case you didn't know, as a phone headset, with the microphone activated, you only get sound in your left ear, and the light flashes blue. For music, you get both ears, and it flashes green. So if it ain't green, you are in mono mode.
37helpful
3answers
My left earbuds on my JVC gummy earphones went out.
I have this problem all the time with my JVC earbuds. This may sound a little gross but it will work. I put the ear phone in my mouth and **** on the end of it pretty hard. What I have found is that sweat or even wax will plug the little hole and prevent the sound from coming out.
Top Sennheiser Audio Players & Recorders Experts
 Grubhead
Grubhead
john h
Are you a Sennheiser Audio Player and Recorder Expert? Answer questions, earn points and help others
