SOURCE: Is there a way to disable the Bluetooth and WiFi at an administrative level?
install a program called symbol appcenter and you can keep people from accessing anything you do not want them to access, I have it installed on mine for an inventory system and all my employees can access is the inventory system. As the administartor I have the password if I need to access anything else in the scanner to ake changes, but nobody else can.
SOURCE: Cannot read symbologie/BarCode: i25(interleaved 2
You will need to configure the telnet emulator from your pc first and download it to the terminal after.
Check the version of telnet emulator you have. To do this, go to the options menu on the emulator and click on about wavelink.
Register yourself on www.wavelink.com and download the same client version as installed on the terminal. (Don't forget to download the Active sync version.
Tweak all the configuration parameters on the emulator once you have installed it on your pc also enable i2of5 symbology and then download the config only to the terminal.
SOURCE: Hi, I'm writing a php page to be used on the
You need to do something like this...
<script>
function enableScanner(enable)
var objGeneric = new ActiveXObject("SymbolBrowser.Generic");
if (enabled)
objGeneric.InvokeMETAFunction('Scanner', 'enabled'); /* Enables the scanner */
else
objGeneric.InvokeMETAFunction('Scanner', 'disabled'); /* Disables the scanner */
</script>
<input type='text' name='field' onFocus="enableScanner(true)" >
SOURCE: first time connection?
The MC9090 does not require any installation.
All it requires that you have ActiveSync installed on you PC. That can be downloaded directly from Microsoft. got to www.microsoft.com and just seach for activesync.
Just make sure that the MC9090 is configured to comminicate via USB
Settings >> System >> USBConfig
Make sure it is set to [USB Client Mode].
Also
Settings >> Connections >> USB to PC
Make sure that [Enable advanced network functionality] is ticked.
If you need any more help dont hesitate to contact us
www.biastechnology.com
[email protected]
SOURCE: Cant activate PCCARD-PHOTON1 in Symbol MC9090
First thing is to run the wireless utility.
Start >> Programs >> Fusion >> WCLAUNCH
Once thats running an icon will apear in the task bar.
Click the icon and select "Enable Radio"
If you need any more help then please do not hesitate to contact us:-
[email protected] or TEL 01202 620955
http://www.biastechnology.com/
