Technics SL-1200 Turntable Logo
Posted on Feb 03, 2011
I just purchases a Technics 1200 turntable for $70.00. I have found a problem, at the end of the album, the arm does not auto return, but just stays on the album. Could this be a simple problem, operator error or stupidity, or require a major fix.
Anonymous
Level 1:
Problem Solver:
  • Contributor 5 Answers
  • Posted on Apr 15, 2011
Anonymous
Contributor
Level 1:
Problem Solver:
Answers
5
Questions
0
Helped
4028
Points
9
First off, Congratulations on such a excellent deal! That's a $500.00 turntable. I know I own a pair and I've been a DJ for 18 years.
Second, the Technics 1200 does not have an auto return. You have to pick up the needle and bring it back manually.
I have a jvc jl-a20 auto return turntable and the arm briefly returns then proceeds to travel across the album. What do I have to do to get it to stay at home after it returns? Thank you
It's probably some kind of mechanical problem. Perhaps something bent out of place.
I have found a photo which is the underside of the model. You can compare it with yours and see if it looks the same. If it doesn't (assuming it is the same model) then you have found the problem.
http://www.vinylengine.com/turntable_forum/gallery/image.php?mode=large&image_id=30141
2answers
Tone arm on technics Sl-BD22 lifts before the end of an album
the anti-skate is set wrong, this stops the arm skatting on to the label in the middle of the record & destroying your stylus tip.
6helpful
2answers
The arm will automatically return without playing the record
Hi Lisa, its a bit of a long shot however try this. With the turntable powered of manually rotate the platter approx 12 times to reset the auto operation back to default. John styluscity.com
Tone arm returns before album is over...can this be adjusted?
of course this is adjustable but needs a good hand for it and a service manual would be great...
Turntable technics sl d93 when arm in ready to
hi, there is a rubber grommet at the base of the tonearm on the left side. Remove and insert a flat blade screw driver. Adjust and test until remedied. Cheers John. Stylus City.
The cartridge arm does not go back to the off position.
it's a "manual" turntable so this is normal. You would need to buy an "automatic" turntable to have the arm return back when done.
1helpful
User manual Technics DZ-1200 turntables & Pioneer DJXM600 mixer
I found your manuals below:
Technics:
http://www.givemefile.net/manuals/musical_instruments/technics/sl-dz1200.html
Pioneer:
http://www.nodevice.com/user_manual/pioneer/dj_mixer/djm-600.html
4helpful
2answers
Technics SL-1350 Direct Drive Turntable
Hi
Check that the cuing lift isn't touching the arm as it gets to the end of the record.
John w
Top Technics Audio Players & Recorders Experts
 Grubhead
Grubhead
ZJ Limited
ZJ Limited
Kolbrun...
Are you a Technics Audio Player and Recorder Expert? Answer questions, earn points and help others
