E 06 means slow or no drain//not a easy do it yourselfer machine//you will need to get to the pump might be plugged//for the do it yourself you can get to the back( but this won't be easy) most techs if they know the machine will take front of that takes pratice//anyhow take rear panal of you will see drain pump in there remove tub to pump hose most likely has some items inside//note some bosch washers have small pump drain hose to get water out before you remove pump hose/if it will drain do that first save alot of mess...........(((( check this first))) note some have round cover at lower bottom put pointy item in hole of cover turn to release ( it will turn hard) some also had cleanout behind that cover/ if so check pump from that location much easier then taking back of.....Hope this helped if it did please vote...if you need more help please ask ...good luck
Bad advice telling people to remove back cover to access the pump. 95% of Bosch washer pumps need to be accessed from the front but this should be left to a qualified Bosch engineer or you risk damaging the pump or other components and flooding the kitchen.
Trust me I am a Bosch engineer.
