Music Logo
Posted on Feb 03, 2011
I have a Clavinova 35/55/65 and 3 keys have stopped working. Did spill a coke there 10-15 years ago but except for the keys sticking a bit everything worked until now.
Anonymous
Level 1:
New Friend:
  • Contributor 2 Answers
  • Posted on Feb 03, 2011
Anonymous
Contributor
Level 1:
New Friend:
Answers
Questions
Helped
1126
Points
6
I couldn't find any tech data for 35/55/65, but it looks to be similar to a large Yamaha I had to repair a couple of months ago for this same issue.
Keyboards can be practically difficult to work in, and can have very fragile interconnects. I wouldn't recommend anyone unfamiliar with working with electronic equipment and the risks involved to attempt this repair.
It may well respond to careful cleaning of the rubberized contact strip that sits under, and is actuated by, the keys. The pcb pads underneath that act as contacts should be cleaned too. It's a good idea to remove any loose dust and debris with a vacuum and a soft brush before lifting the contact strip out, this reduces the likelyhood of introducing problems on other keys. I then used some isopropyl alcohol and a cotton bud on the underside of the strip and the pcb pads. Very little pressure should be used in this process, as extremely fine layers of gold are involved, it's vital for reliable contact. I prefer not to clean areas for keys which were not affected.
There may be an additional issue, if the coke really was the cause then there may also have been acid corrosion of pcb track over the years. This should be repairable though. Inspection with an illuminated magnifier is recommended, or a cheap USB microscope will do a good job too.
Personally, I would say that this really is a job for someone qualified and experienced.
Testimonial: "The advice seemed to be very insightful."
I can't connect a usb device with music on to the clavinova.
You have to format the USB stick using the Yamaha Clavinova. The reason is that the keyboards expects certain file/folder structures on the stick. If you format it on the computer, the computer will not know what files or directories to create for the Clavinova when it formats the stick.
How do I get into the keys of my Clavinova 409 - they're sticking
Firstly take a look at the keys that are sticking. Are they leaning slightly to the left? The gap on either side should be equal, you should be able to slide a business card freely into the gap.
If they are leaning to one side it is a sure bet that the key has broken on the fixing under the bank of switches.
You will need to dismantle the keyboard and remove the broken key ( and the bit that has probably broken off ) and replace it.
Replacement keys can be found at www.beckettsmusic.co.uk if required. If you need further assistance contact via the links on the site.
Dec 22, 2014 • Music
Yamaha clavinova repair
I Bim
which clavinova model you have
Jan 19, 2014 • Music
Water spilled keyboard
turn the instrument slant with keys facing you keep for some time ,and with heir dryer dry it with normal hot air
Yamaha clavinova cvp-83s
Hi, did you manage to sort your problem as the same thing has happened to my clavinova (same model). Thanks.
1helpful
Key sticks.
take it to the shop for repairs
2helpful
2answers
Keys stick on Clavinova CLP 360
A contact rubber for CVP-35, part number VS549800 will work, that's how I fixed my sensor problems on my CLP-360.
Yamaha clavinova won't play C natural in any octave
Hi ...
There are flexible cables that connect the keys to the main electronics. The connectors for those cables sometimes age poorly..
It is fixable. But dont "get taken" on a repair.
If it's just resoldering a few points,it shouldnt be more than $100.00
to fix
2 keys(reeds) are not working ,my keyboard is yamaha DGX200,how to open it
It is a design fault. A technician advertising on the net informed me i can get it fixed by him and yamaha will pick up the fee.
Nov 12, 2008 • Music
Top Yamaha Music Experts
Paul Bade
Are you a Yamaha Music Expert? Answer questions, earn points and help others
