Question about Ricoh Aficio 1515MF All-In-One Laser Printer
Ricoh 1515 is locked up with error message SC:820 code 612. How do I fix the problem
  • Ricoh Master
  • 525 Answers
820 Self-diagnostic error: CPU
Symptom:
• An unexpected exception or
interruption occurs during the self-
diagnostic test.
• An error is detected in the MBU.
Possible Cause:
• Defective controller
• Defective firmware
• Loose MBU jumper
Code 820
MBU error (The jumper is loose.)
Set the jumper (on the MBU) correctly.
The following codes are displayed:
• SC: 820
• code: 612
• detail: 40000000
Posted on Feb 19, 2011
6ya staff
SOURCE:
Ricoh MP201 SC820 CODE 612 Detail 40000000
[06FF]: Detailed error code
The pipeline clock frequency
rate is different from the
prescribed value.
?? Defective CPU devices
?? Mode bit data error, which is used
for initializing CPU.
1. Replace the controller board.
Apr 09, 2017 | Ricoh Aficio MP-201 Copier w/ Duplex...
SC 820 code 612 Detail 40000000
Clean MBU interface. Clean with dev. Make sure you can see gold pins. Clean male adapter on MBU board with dev. Pic : SP201 ricoh MBU clean up with dev.
Feb 14, 2013 | Ricoh Aficio 1515MF All-In-One Laser...
Ricoh 820 sp c 820 error sc 548
An SC548 error code indicates a fusing unit installation error. I would suggest that you turn the machine off, pull the fusing unit out, inspect it for any obvious damage, put it back in, and turn the machine back on. If it still doesn't work after reseating the fusing unit, it is likely that there is something wrong with the fusing unit and I would recommend that you seek professional help.
Feb 28, 2011 | Office Equipment & Supplies
Ricoh Oficio 1515 tengo el eror SC 541
Fusing thermistor open error
Symptom: The fusing temperature remains lower
than the specified temperature by 20
degrees Celsius.
Possible Cause:
• Defective thermistor
• Incorrect installation of the thermistor
• Defective power supply unit
• Loose connectors
Dec 04, 2010 | Ricoh Aficio 1515 All-In-One Laser Printer
My aficio 1515 have a code SC541
sc 541 is a fusr error. please email me on ronils_singh@yahoo.com.au so i can email you a procedure to reset the code.
Sep 28, 2010 | Ricoh Aficio 2015 Copier
Ricoh 1515
Turning the main power switch off and on, resets the SC code if the error is caused by incorrect sensor detection.
If the error is still there, the laser synchronising detector or laser diode is faulty. Please call a service engineer.
Good luck and please rate me, thanks.
Jan 13, 2009 | Ricoh Aficio 1515MF All-In-One Laser...
Printer wont do anything ricoh aficio 1515 pcl 6
The first thing to try is to turn the machine off, then back on at the red "main power" switch located on the left side of the machine. If the code returns it is indicative of firmware problems or a loose connection.
At this point I would seriously recommend getting a service tech to come out. However, if you want, you can take off the back cover (MAKE SURE THE POWER CORD IS UNPLUGED) and double check all of the connections by (GENTLY) pressing them into their connections. Hope this helps. Let me know.
Mar 31, 2008 | Ricoh Aficio 1515MF All-In-One Laser...
Ricoh Aficio MP C1500SP - functional error SC202
call ricoh serviceman he/she can fix it.
Defective tank full sensor
• Tank full lever bent or broken
• Incorrect ink suction
1. Check the harness of the tank full sensor.
2. Replace the GJ engine.
3. Replace the maintenance unit.
• The position of the tank full lever
does not stay at the tank full position
after ink initialization or air releasing.
• The position of the tank full lever is
not detected at ink suction.
Aug 19, 2007 | Ricoh Aficio 1515 All-In-One Laser Printer
Ricoh Aficio 1515MF All-In-One Laser Printer Logo
2,932 people viewed this question
Top Ricoh Office Equipment & Supplies Experts
gggg
Adorjani Laszlo
quennie732
Are you a Ricoh Office Equipment and Supply Expert? Answer questions, earn points and help others
