Most any kind of 4-cycle motor oil like 10W-30 will work in these motors. After draining the old oil replace the drain plug. There are two types of motor oil fill holes: 1. If you have a motor with the oil fill/check hole on the bottom of the motor and a small screw-in plug either with or without a small dip stick on it; with the motor level, fill the crank case with oil until it is up to the threads on the oil fill/check hole. 2. If you have a motor with a long dip stick that goes into a filler tube at the top of the motor, again with the motor level, put in about half a quart of oil and use the dip stick to check the oil level. If not full, add quarter quart amounts and check again until the oil is at the full mark on the dip stick. Do not overfill the crank case with oil. Most motors will take about one quart of oil but it varries so watch to see the oil level come up to the proper level.
