Lg 42px-4dv/ea sustain pcb fails after 6 hrs running.
  • 1 more comment
  • lemsip Jul 21, 2008
    the item is not under manufacturers warranty
    replaced y-sus pcb ran ok for 6 hrs then y-sus pcb failed.
    it is 4years old
  • 105 Answers
Try to reset the whole unit
Posted on Jul 21, 2008
  • 38 Answers
How long have you had the TV?
  • 2,071 Answers
Try hard resetting;
NOTE:
Some TVs have a reset button. If available and accessible, try using the reset buttons before using the steps below. Using the reset buttons can save time.
Figure 1: Example of the reset button labeling on the LC2600N
lg 42px-4dv/ea
1. Unplug the TV power cord from the power outlet.
2. Unplug any connected devices (DVD, Set-top boxes, etc...)
3. Press and hold the TV power button for five seconds.
4. Plug the TV power cord back into the power outlet and turn on the TV.
5. Open the on-screen menu to confirm that the TV is responding again.
6. Turn off the TV and reconnect the devices.
7. Turn on the TV.
  • LORETO LACARON
    LORETO LACARON Jul 21, 2008
    it is caused by failure of the YSUS board.Now this board is not
    available by itself as LG have released a repair kit for this series of
    plasma which contains the YSUS, ZSUS and CONTROL boards.It is safer to
    replace all 3 boards as sometimes the other 2 boards are damaged when
    the YSUS fails.
    These kits are available from Statewide Appliances PH: 1800 005 220
    Part Number is: 6871VSNB03
    Guru:
  • 1,894 Answers
PCB fails means??
did you open the unit and inspect the PCB
  • 813 Answers
Your tv is in warrenty or not
6ya staff
SOURCE:
I have an LG RU-42PX11 plasma tv. A couple weeks ago we heard a pop and the picture went blank. I can still change channels via cable box and I have sound but no picture.
6871QCH034A PCB ASSEMBLY,DISPLAY CTRL ASSY 42V6 NEW MCM(1222) LVDS
202 6871QDH066A PCB ASSEMBLY,DISPLAY YDRV ASSY 42V6 YDRV TOP ASSY
203 6871QDH067A PCB ASSEMBLY,DISPLAY YDRV ASSY 42V6 YDRV BTM ASSY
204 6871QLH034A PCB ASSEMBLY,DISPLAY XRLT ASSY 42V6_XL(4LAYER)
205 6871QRH037A PCB ASSEMBLY,DISPLAY XRRT ASSY 42V6_XR(4LAYER)
206 6871QYH029A PCB ASSEMBLY,DISPLAY YSUS ASSY 42V6
207 6871QZH033A PCB ASSEMBLY,DISPLAY ZSUS ASSY 42V6
These are the part numbers for all the boards that deal with the display. Im leaning towards the sustains as well and you need to do both at the same time cause if one is bad and you replace just one, a bad one can fry the new one.
If you need further help, reach me via phone at https://www.6ya.com/expert/steven_a67ead41eb5fc62a
Jan 20, 2017 | LG Televison & Video
LG PDP42X3 No Picture - I have sound and blue power button in front but no picture. How do I tell if the ceramic fuse is blown? They are all still pure white. If they are not blown, does that help with...
This condition, sound no picture, is generally a result from a failed y-sustain and/or x-sustain board. You can check the fuse for continuity or resistance using a multimeter. I am helping someone repair their LG 42pc3d, that's why I thought I'd help you out too.
Y sustain board 6871QYH053B
Z sustain board 6871QZH056B
Jan 09, 2010 | LG 42PC3D 42 in. Plasma Television
Black haze covering picture after "pop" noise
That's a very old model to be only 1 year old?
It needs a Z-Sustain PCB anyway.
Thanks.
Sep 08, 2009 | LG DU-50PZ60 50 in. Plasma Television
50 inch Sanyo Vizon Plasma TV. Has sound but no picture for last few days. 2 years old
This set has LG insides, it will have failed on either the Y-Sustain PCB or the Z-Sustain PCB.
Quite common.
Repair estimates should be $250 - £350 depending on which has failed.
Stick it on eBay, it will fetch good money faulty.
Sep 06, 2009 | Sanyo Televison & Video
Any info on picture problems with LG 50PX1D-UC Plasma? The picture is slighly fuzzy and seems to pulse in brightness
Your TV is going to need a Z-Sustain PCB.
The Z-Sustain controls the contrast of the image, it is also a common part to fail.
Sep 06, 2009 | LG Televison & Video
LG HDTV...Have sound, but no picture!
I do not think you need a Y-Sus, you need a Control PCB.
6871QCH060Q.
The Y-Sustain part number you have given does not match the one in your TV, close, but nope.
6871QYH030C is the Y-Sustain number.
Your set needs a control PCB. It is a common Fault.
If you are in the USA, eBay, www.shopjimmy.com
If you're in the UK, then www.fixmyplasma.co.uk, charles Hyde, SEME Nedis.
Not cheap though.
Sep 05, 2009 | LG DU-42PY10 42 in. Plasma HDTV
I have an LG 42 PC 5D it just shut off on me last night and won't turn on today. The green on button comes on then the red comes on right after it. what could be the problem.
Most likely the Y-Sustain PCB.
6871QYH051P if it's a 42X2 PDP Module
6871QYH053B if it's a 42X3 PDP Module
It depends on when it was made as to which is fitted.
I'd bet the fuse(s) are blown on it, signifying it has failed.
They are about £200 New from Charles Hyde. www.chsinteractive.co.uk
Sep 03, 2009 | LG Televison & Video
I HAVE A LG 50PXD1 MODEL AND I have picture and sound, but the picture is very dim. I can still use it but have to close all the blinds to see the screen. any ideas?
A dark picture is commonly caused by a failed Z-Sustain PCB. This is the most likely.
It could however also be the Y-Sustain, however it is rare to still get an image at all.
Sep 03, 2009 | Televison & Video
Televison & Video Logo
314 people viewed this question
Top Televison & Video Experts
Marvin
Marvin
