The covers are 99% of the time plastic, and if broken will cost around $3 to replace if you break them.
The caps are a two part systema base that goes below the nut and the top dome that covers the assembly.
See here: http://www.plumbingsupply.com/images/toilet_bolt_caps_green.gif (ignore the special color)
These two pieces snap together and with a slotted/flathead screwdriver should just pop off with a little bit of convincing. If they are too loose that the screwdriver will not work a claw hammer can also pop them off. If all else fail, break them. They serve completely aesthetic and no actual function beyond, however they are easier to clean and may assist in the reduction of bacteria growth.
