Question about Dean Vendetta XM Electric Guitar
The wiring is no longer attached to the volume tune knob or jack i need shcematic so i can repair
  • Dean Master
  • 5,603 Answers
Here is a site:
http://www.1728.com/guitar6.htm
In the schematic ignore all the extra switches and junk. The output jack and volume control is all you need to wire it back up. The view of the volume control is from the back.
Posted on Feb 04, 2011
6ya staff
SOURCE:
Dean razorback db electric guitar knobs
the knob closest to the neck is your volume. And the other two are tone. one is tone for bridge p/u & other is tone for Lead p/u. which is which can vary. you'll just have to listen. hope this helps
Jan 31, 2012 | Dean Razorback Db Electric Guitar
How the f53k do hook fender cd60ce accustic guitarto sound sourca when there no jack on guitar just tuner egualizer and volume knob must be able to hook to sound sourcs what reason for volume knob
Just to clarify : Is this a wire less type working on FM in which case you will need to have the receiver unit connected to the Fender amp or try if this tunes on a receiver.
Oct 18, 2011 | Music
Hi! I need two input/output plates for my Kustom floor monitors (KSC10ML). By input/output plate, I mean the unit that has the volume knob plus the two input/ output jacks that is screwed ino the side...
The KSC10ML has NO volume control... only two 1/4 inch jacks. To get a matching "jack cup" you will probably have to go to Kustom. I have searched for the item on the web and only jack cups that seem to come up are for Marshall or ones that use binding posts. I found one blank one but it is 5 by 7 inches... too big for that Kustom cabinet. In a pinch if you don't need it to be recessed, cut metal or ABS plastic plates and drill for two jacks.
Apr 16, 2011 | Kustom KSC10ML PA Monitor
Input jack is broken
VERY common problem... this is why you ALWAYS loop your cable through the handle. One trip over a guitar cable and the yank sideways destroys the jack... AND the jacks are really weak and poor to start with... Take the thing in for repair, or if you are electronically adept replace the jack yourself. MOST of these have the jack soldered to a circuit board and one often has to remove all the front knobs and the nuts holding the volume controls and move the bord back to remove and replace the jack...
Nov 26, 2010 | Fender Rumble 100 Bass Guitar Amplifier
Black cables loose
Does the jack have any wires connected to it? Can you tell where the disconnected wires originate? Typically, the wire from the middle ear of the volume pot should go to the tip of the jack, and the wire from the back of the tone pot goes to the sleeve of the output jack. You will get no output if either of these wires are disconnected. Also, the next question is "why" did they come loose? That's usually because one of the pots is not tightened down, and is allowed to spin when the volume or tone knob is turned, breaking the wire's contact. Pull the knob off the pot, and tighten the nut down so the pot can't turn. This will assure you won't have the same problem again.
May 26, 2010 | Dean Vendetta XM Electric Guitar
My guitar volume won't turn off
the problem i analyse is 1) the wires of the volume control (it has three wires wired to the input of the amplifier) wire 2 and 3 have got shortened.
2) the field effect transistor of the preamplifier has got shortened . the fet is in built in certain guitars.3) if its wire wound volume control then it has lost grounding , that is wire no 3 has lost its grounding (usually this is associated with a hum from the amplifier
Sep 19, 2009 | ESP Ltd EX-50 Electric Guitar
Peavey 115 Low hum Low volume from input
The preamp section has a problem. It could be anything in the preamp but is OFTEN the input jack itself. They take a lot of abuse.
Also the insert jack contacts that forward the preamp to the power amp if no external FX are used can go bad.
Additional things are circuit board cracks caused by rough handling and also controls that have had the knobs mashed in which can destroy the potentiometers they are connected to.
Sep 19, 2009 | Peavey Music
Dean Vendetta XM Electric Guitar Logo
111 people viewed this question
Top Dean Music Experts
Michial Gueffroy
Cameron Lewis
Cameron Lewis
Level 1 Expert
STEVE
Are you a Dean Music Expert? Answer questions, earn points and help others
