Question about Nintendo Wii Remote Controller
All of the blue lights are blinking, but doesnt connect to wii console , The pointer hand doesnt show up on screen
    Problem Solver:
  • 17 Answers
You need to press the red snync button on the WII console- its on the front under the white lid. Then do the same on the wii controller.
Posted on Feb 04, 2011
6ya staff
SOURCE:
Cannot get cursor on screen , replaced sensor bar , but no joy ??
Does your Wii connect with your wii-remote(1 blue light on and not blinking)? If not try re-sync the wii-remote:
http://www.wikihow.com/Synchronize-a-Wii-Remote-to-the-Console
Apr 19, 2015 | Nintendo Wii Console
I can't connect my controller to the wii console. Model number Rvl-001(USA). Model of nyko pistol accessory is Bn:090907 4632.My mom threw out the manual out by mistake.HELP!
  • Turn on your Wii console. While on the HOME screen, press any button on the Wii Remote.
  • If the 4 squares on the bottom remain dark, change the batteries (or for a rechargeable Wii Remote, place it on the charger for a while).
  • If the 4 squares blink blue, then stop, your Wii Remote is not synced. Press the 1 and 2 buttons at the same time. This should connect your Wii Remote if it's been synced before.
  • If your 4 squares still blink blue, then stop, these last steps will do the trick. First, on the front of the Wii console, just underneath the disc slot, there is a small panel that opens down. Open it and press the small red button.
  • Open the battery panel of your Wii Remote and press the small red button. Replace the battery panel and observe the blinking blue lights. If 3 stop blinking, and 1 remains lit blue, your Wii Remote is synced with your console.
May 13, 2011 | Video Game Consoles & Games
My wii remotes are not responding to my wii unless i am within a foot of the receiver anyone know why? and how to fix it, thanks
  1. Access the Wii System Settings
  2. Click on the blue arrow to reach the Wii System Settings 2 menu options.
  3. Choose "Sensor Bar " and select "sensitivity"
  • Use the Wii Remote to get the cursor to get the two white dots in the test field.
  • If you see two blinking dots, then the sensitivity is currently set correctlyIf you don't see two blinking dots (they don't have to blink at the same time), adjust the sensitivity with the + and - buttons of the Wii Remote until you see two blinking dots.
  • Select "Confirm" to save the setting.
Please note that the higher the sensitivity setting, the more sensitive the Sensor Bar becomes to sunlight and various light sources. This may impact the operation of the Wii Remote. The initial recommended distance for using the Wii Remote Pointer is 3 to 8 feet from the Sensor Bar.
Seeing more than two dots?
If you see more than two dots on the Sensitivity screen, then the Wii Remote is picking up on additional light sources. Verify that there are no bright light sources, including sunlight, behind or near the TV, shining towards the Wii Remote or reflecting off the TV screen. Avoid sources of infrared light in the gameplay area such as electric, propane or kerosene heaters, flames from fireplaces or candles, and stoves or other sources of heat.
Jan 16, 2011 | Nintendo Wii Console
I can not re start my nintendo balance board,
1. Insert a Wii Balance Board compatible game disc in the Wii console.
2. Use the Wii Remote to select the Disc Channel from the Wii Menu, then select "Start" to begin the game. Press the A Button to bypass the wrist strap screen.
3. Open the small SD Card slot cover on the front of the Wii console.
4. Remove the Battery Cover on the bottom of the Wii Balance Board.
5. Press and release the SYNC button on the Wii Balance Board. The blue light on the board will start blinking.
6. Press and release the red SYNC button on the Wii console while the blue light on the board is still blinking.
7. The blue light will stop blinking and stay on steady once the syncronization is complete
Dec 20, 2010 | Nintendo Wii Fit - Balance Board + Game...
MY WII BALANCE BOARD IS CHARGED BUT THE BLUE LIGHT WONT STAY ON.
  7. The blue light will stop blinking and stay on steady once the syncronization is complete.
click here to download repair guide if u want
Dec 15, 2010 | Nintendo Wii Fit - Balance Board + Game...
My wiil remote will not connect to the console when i turn it on the blue light flashes but doesnt not connect
  1. Press the Power button on the Wii console to turn it on.
  2. Remove the battery cover on the back of the Wii Remote you wish to sync up, and press the SYNC button just below the batteries. The Player LED will blink.
  3. Open the SD Card Slot cover on the front of the Wii console and press the SYNC button on the inside of the compartment.
  4. When the Player LED blinking stops, the syncing is complete. The LED that is illuminated indicates the player number (1 to 4).
This procedure must be followed for each additional Wii Remote added to your system.
hope this helps
Nov 29, 2010 | Nintendo Wii Console
Bought 2nd hand wii fit, have just loaded disc and replaced batteries in board but power light not staying on board, flashes for about 30 seconds and then switches off. Does it need to be synchronised with...
    Hope this helps
    Try these steps!
  7. The blue light will stop blinking and stay on steady once the synchronization is complete.
please leave a good rating and testimonial if you appreciate my help. THNX
Mar 27, 2010 | Nintendo Wii Fit for Wii
How do i resync my wii controler
follow the steps descrived below:
1.Turn on your Wii console. While on the HOME screen, press any button on the Wii Remote. If the 4 squares on the bottom remain dark, change the batteries (or for a rechargeable Wii Remote, place it on the charger for a while).
2.If the 4 squares blink blue, then stop, your Wii Remote is not synced. Press the 1 and 2 buttons at the same time. This should connect your Wii Remote if it's been synced before.
3.If your 4 squares still blink blue, then stop, these last steps will do the trick. First, on the front of the Wii console, just underneath the disc slot, there is a small panel that opens down. Open it and press the small red button.
4.Open the battery panel of your Wii Remote and press the small red button. Replace the battery panel and observe the blinking blue lights. If 3 stop blinking, and 1 remains lit blue, your Wii Remote is synced with your console.
Mar 03, 2010 | Nintendo Wii Console
The pointer or "hands" dont work properly
If the pointers don't show up it is a strong indicator that the sensor bar isn't working or connected properly.
I don't think that it has anything to do with internet access but your wireless router should work fine as long as you have a USB wireless access card and then go into your settings and connect the devices, which is an easy process.
Jan 03, 2010 | Nintendo Wii Console
Remotes can't be found
When you change the batteries for a Wii Remote (in my experience) you have to re-sync (reconnect) them to the Wii console. To do this, there is a button on the Wii Remote by the batteries that either says sync or will show curved bars on I think i red button. This same button should be located on the Wii console. You have to push the sync button on the Wii then on the remote to sync them together. This should solve your connection problem.
Apr 29, 2009 | Nintendo Wii Console
Nintendo Wii Remote Controller Logo
842 people viewed this question
Top Nintendo Video Game Consoles & Games Experts
Raj Patel
Julian Wainwright
Ekse
Are you a Nintendo Video Game Console and Game Expert? Answer questions, earn points and help others
