Question about Sony KLV-S32A10 32 in. HD-Ready LCD Television
Big picture ( channals, video,and dvd are still or puse). and pic and pic is perfect what are the salution?
    Scholar:
  • 113 Answers
You need to change out the caps on the video processing board,caps (smd) type have gone bad ,must replace the caps by exp. or qualified tech,must be able to unsolder and solder components ,make sure to clean board with some denatured alcohol ,board gets saturated by electrolyte that leaks out of the caps,common problem ,happens in all electronics,that or take it to the shop,caps look like little silver round cans
Posted on Feb 04, 2011
6ya staff
SOURCE:
I loss view of my cable channals after watching DVD.
if you have a snowy picture when you move around the channel selector you probably have a bad solder connectionand must have it repaired by your tv man
Dec 18, 2009 | Emerson EWC19T3 19 in. TV/VCR/DVD Combo
I have an Onkyo TX-SR606. With an HDMI connection from any dvd player connected to the HDMI/DVD in on the Onkyo I get perfect pic and sound initially then the picture starts to go bad, usually about 5 - 10...
Hook your HDMI directly ffrom the DVD to the TV, then connect digital coaxial or optical to your receiver for audio. Your receiver will not current HDMI video codecs. That is the only fix. Sorry. Hope this helps.
Sep 25, 2009 | Denon AVR-3806 Receiver
Picture too big
there will be a button on the remote that says aspect, or pic size, hit that button, untill you get the size you want, if you cant find the button, go into the menue, click the picture, or video section, and look for aspect racio, or pic size in there
Jan 09, 2009 | Polaroid FLM-4201 42 in. LCD Television
DVDs are playing with green tinge
Greetings and Salutations,
If your using the component outputs from your DVD player I would first check to make sure that the cables for the Red and Blue channels are connected properly. If the cable is connected correctly then try replacing both the Red and Blue channel cable. If this fails to fix the problem try connecting to another component input on your TV if you have one available.
You might also want to check to see if you switched on the progressive scan switch on the back of the VCR/DVD unit. If you know someone with another DVD player have them bring it over and see if the problem is still exists.
If the green picture is still present then the problem is and internal problem with the TV and you will need to find a repair center for it. If the problem goes away then the problem is with the VCR/DVD combo unit. You can at this point also try using just the Video Out from the DVD player.
Hope these suggestions will help you with your problem.
Jan 06, 2009 | Toshiba SD-37VSR Player
Dvr4-alert full screen playback
That's because this is a quad. It compresses all 4 video feeds into 1 file. When you play it back, it decompresses the video and shows you each camera. Playback through this unit is the only way to see 1 camera at a time.
To be able to copy 1 camera shot to a DVD, this is what you need to do: You need to have a TV with Video in and Video out jacks.  Connect the Quad to the TV Video in jack and connect the TV Video out jack to your DVD Video in jack. Playback a single camera shot on the quad to the TV and hit record on your DVD. - The DVD will record whatever is shown on the TV.
Oct 26, 2008 | Home Security
Flash
What's perfect to you may not be perfect to someone else, That is why this pro grade camera offers so much in the way of adjustments. One doesn't often GET the perfect picture. More often, one must CREATE the perfect picture..
Set the flash at "0" for the most uniform pictures, and try a better lit environment and work in the 4' to 8' range. Generally, your pictures taken outside in good light, with the sun at your back will be the best. The rest, especially flash, often require some manipulation of the environment..I.E. lighting.
A perfect picture requires a perfect subject, perfect pose, perfect foreground lighting, and perfect background lighting.
So, the answer to you question is; there is no perfect setting, which will constantly produce perfect pictures.
Good Luck..
Aug 28, 2008 | Konica Minolta Maxxum 7D / Dynax 7D...
Trying to hook up dvd player with sanyo tv. Also hook this up to satellite and surround sound. No picture, just audio.
Well are you ready for this I hope you can under stand if not maybe I can draw a diagram. Starting with your stereo take the component video out and goto component on the back of your tv to component in then the stereo coaxial in to the digatl audio out on the DVD player then DVD player anntena out to TV anntena in then DVD anntena in to reciever anntena out and Sat cable to reciever. also s-video on Dvd componet to s-video on TV DVD player Audio out to Audio in on TV. Set Stereo to TV and DVD player to channal 3 or do auto scan and TV will work on 3 with the reciever and also TV works with Video 2 I hope this works for you good luck
Jan 03, 2008 | Sanyo DS31590 31" TV
Goodmans tv/video/dvd all in one
Perfect picture on TV, DVD and VCR, but no color means you have selected the wrong color system.Since you are in the UK, make sure that the VCR Color system is also set to PAL. Perhaps it is wrongly set to SECAM?
May 04, 2007 | Goodmans 217NS TV
Channal Search
Im sorry but you can't without the original remote. If you want to consider getting the remote go to http://www.remote.com or maybe you can borrow one from a freind or a local store that sells Emerson will let you borrow one. Good Luck
Aug 13, 2006 | Emerson EWC19T3 19 in. TV/VCR/DVD Combo
Sony KLV-S32A10 32 in. HD-Ready LCD Television Logo
Top Sony Televison & Video Experts
Jerry Greenberg
Jerry Greenberg
Ekse
Are you a Sony Televison and Video Expert? Answer questions, earn points and help others
