Dead (ish) Laptop. Press the power button momentarily to check if it is hibernating or in stand by. If this doesn't work; Try firstly removing the laptop's
battery as it may be at a critical voltage and the system will not
start because of it. Plug in your ac adaptor and monitor what
happens. Does the power light illuminate? If it does it should then
boot up, if it doesn't, try a known good ac adaptor before going any
further.
If the adaptor is fine and the laptop still won't start,
then you may have a mother board fault and should contact a
dealer/repairer for further advice.
Hope this helps.
