Try pressing the input or source button on the remote
Hello
Your tV is telling you the truth. It does not get any signal from anywhare at all. There are to possibilities for this display messege. The frist one is external, that is, Tv is not connected properly to any input source. Check the input connections forst and make sure that all are correct, according to your TVs user manual says. First of all connect it to an external antenna, and set the tv to autotune mode, and find whether it searches for channels for air and memorizes all the transmitted channels at that time. If it does, make sure that, you have connected other inputs incorretly, or node selector is in worng select position. This can be set by going through the Menu options. If the tV doesn't tune on air channels, when you connect it to external antenna, and tuning indication is on, either it memory IC or its Tuner has trouble. To rectify this fault, you have to open your tV, and locate them, resolder them, and replace them with identical one both in type and number. OK.
I think you probably just switched from digital to analogue mode or vice verse. Press the TV button on the remote first to make sure you haven't selected an external input. Then look for a button on the remote labelled "DIGITAL" or "DTV". This is often located above the numerical keys, above the "1". If you need further assistance, please post back and confirm the correct brand and model number of your TV. Thanks.
