Question about Quinny Buzz Jogger
I have a quinny buzz and my pareents have forced the mechanism to remove the seat when they were babysitting. I have managed to find most of the parts that came out when it broke and put them back together, but the white plastic part inside the hole where we insert the seat is missing (the plastic part is necessary to adjust the seat and set the incline. It is round, white and about the size of a quarter, with 4 little rectangle bits sticking out) Is this replaceable? thanks for your help
  • Quinny Master
  • 1,637 Answers
Hi - Please can you visit the Quinny page and use the 'contact us' tab for your enquiry to be directed to the customer care team in your country who can help you. http://www.quinny.com/international
Posted on Jun 05, 2017
6ya staff
SOURCE:
Anonymous
SOURCE: Quinny buzz
go to www.quinny.com/media/producthandleidingen/Quinny/01638_inst_ES_083107.pdf
Posted on Jan 10, 2008
Anonymous
  • 4 Answers
SOURCE: quinny buzz
Tyres-press the light grey button on the chassis next to the wheel slot as you push on the wheel (this is also the button you press to release each wheel).
Opening it is easy - With Buzzwheels on the ground, remove safety hook (plastic loop on left side of handle fixed to peg inner left rear wheel) ten simple lift handle and Buzz frame should automatically pop up.
Closing takes more practice-put on brakes (press red foot pedal) stand to side of chassis and at bottom end of handle there are two large grey buttons. With left hand on left button push button forwards (ie direction of chevrons on button) then press in. At the same time push in right button with right hand. Whilst doing this you also need to push down and forad on frame and it should fold down. If you don't push buttons enough it can click. When folded remember to put on safety hook before transit, otherwise it might pop up on its own. Hope this helps. You can download the manual with instructions from Quinny website too if pictures are helpful!
Posted on Apr 27, 2008
Anonymous
  • 4 Answers
SOURCE: how do you close quinny buzz
you need to stand at the front of the pushchair, push in the left grey button and then push the right one down and towards you all at the same time!! whilst doing this push the frame down towards the front wheel! when i first got mine had real problems figuring it out once you do its easy!! remember to hook on the safety catch though cause one touch of the handle and it pops open. i did read that in cold weather it can be a little stiff. not sure on the car seat though as didnt have one! sorry
Posted on May 12, 2008
bunnydawg
Roberta Smith
  • 5158 Answers
SOURCE: quinny buzz replacement seat
try here for part sources
http://www.quinny.com/quinny/productdetail.aspx?id=3
Robert
Please rate the solution thanks
Posted on Sep 08, 2008
dutchtexan
  • 60 Answers
SOURCE: How to wash Quinny Buzz 4
Try this web link, it will take you to the owners manual that you can view or print out and show you the answer to your question.
http://quinnybaby.com/info_instructions.asp
Hope this helps, DutchTexan
Posted on Nov 11, 2009
Quinny buzz 3
Hi
Yes the 2013 style sub seat can be fitted to a 2005 chassis. Where the sub seat connects into the chassis there will be a plastic clip on either side of the 2013 sub seat that will need to be removed in order for the sub seat to then fit into a 2005 chassis.
Jul 12, 2013 | Quinny Buzz Baby Gear
How I fit the XL seat for quinny buzz. There doesn't seem to be anything to fix it onto?
Hi
The infant stage seat fabric that the Quinny Buzz was originally fitted with is on a sub seat (seat frame) that is then clipped into the chassis.
Remove the infant stage seat fabric from the sub seat and replace with the 2nd stage seat fabric.
Mar 28, 2012 | Quinny Baby Gear
On the quinny buzz stroller do i need a new frame for the xl seat cover, or will the cover fit the frame of the smaller seat unit?
Good Afternoon
If you have a 2007-2010 model Quinny Buzz you need to remove the infant foam fabric from the sub seat (seat frame) and replace it with the 2nd stage seat fabric (also known as the XL)
For full instructions on how to do this please visit our Facebook page Dorel UK Customer Services and view the Handy Hints & Tips photo album.
Oct 13, 2011 | Quinny Buzz 3 Stroller
HOW TO TAKE SEAT CASE FROM QUINNY BUZZ 3 TO WASH
18a00952-a2f4-4dcc-9e5b-8234daf21e0f.jpg Please find attached Handy Hint guide for removal of Quinny Buzz seat fabric. We advise handwash only maximum 30 degrees. Allow to dry naturally - do not tumble dry. Exposure to direct sunlight may cause fading.
Sep 06, 2011 | Quinny Buzz Three Wheel Stroller
I have a quinny buzz 2005 frame will a replacement seat unit fit this and will the carry cot fit please
Good Afternoon
The original Quinny Buzz 2005/2006 chassis is not suitable for fitting the current seat fabric. However you can purchase a sub seat (seat frame) which will fit onto your chassis (RRP 75GBP) and the current seat fabric will fit onto that (RRP 40GBP). The Quinny Dreami carrycot is suitable for use on any Quinny Buzz chassis. You can order the sub seat and seat fabric via your local Quinny retailer or direct from the customer service department on 01284 413 141 Mon-Fri 8.30-4.30.
Jan 11, 2011 | Quinny BUZZ 3 Capri Stroller
Trouble opening and collapsing a quinny stroller
The Quinny Buzz can only be folded/unfolded with the seat in the most upright position facing forward. If this is the case and it won't unfold, remove the seat first by pushing down the two grey release buttons either side of the frame. It may be the case that the gas strut (automatic close/opening mechanism) is seized and will need replacing. This can only be done by Dorel UK 01842 763 281 as it is a pressurised unit. Hope this helps
May 28, 2010 | Quinny Buzz Jogger
How do you put the cover on the seat?
If it's the new model then you need to follow this in reverse order for Cleaning the Quinny Buzz seats (comfort cushion and XL seat)
1. Open safety harness
2. Unfasten the shoulder belt snap and hook and remove the belt pad.
3. Loosen all snaps on the bottom of the seat
4. Loosen the Velcro straps on the bottom of the seat. Remove the belt buckle through the opening of the seat
5. Slide the cord of the seats out of the edges of the Quinny Buzz seat. Start with the foot section and work towards the head section
6. Pull the lap belt of the Quinny Buzz seat through the holes of the seats and remove the loops from the shoulder belts from the openings of the seat
May 19, 2010 | Quinny Buzz 3 - Juice Travel System...
Can a buzz seat fit speedi frame
No unfortunately not. The Quinny Dreami carrycot can be fitted as can a maxi cosi car seat using adaptors but not the buzz seat unit.
Mar 06, 2010 | Quinny Buzz Three Wheel Stroller
I need to attach the maxi-cosi car seat to the zapp
You cannot fix a car seat to a Quinny Zap. They are not designed for it. In the photo you show a Quinny Buzz 3. You can fix the car seat to this and the seat removes easily
Jul 24, 2009 | Quinny BUZZ 3 Capri Stroller
How to change seat covers on a quinny buzz stroller
Try this link
http://www.quinny.com/media/producthandleidingen/Quinny/08.08%20win1299_Buzz4_UK.pdf
The instructions & diagram are in section 6.2 on page 5 of this 7 page pdf document.
Hope it helps!
Nov 26, 2007 | Baby Gear
Quinny Buzz Jogger Logo
1,502 people viewed this question
Top Quinny Baby Gear Experts
Dorel UK
Dorel UK
doobuster
Tom Chichester
Are you a Quinny Baby Gear Expert? Answer questions, earn points and help others
