Question about Vizio P50HDTV20A 50 in. Plasma HDTV
Turned the tv off few hours ago and came back and now it wont turn on - checked all connections - still no power - can not turn on from remote or on side of tv.
  • Vizio Master
  • 8,457 Answers
Check the power outlet source?Yes,tries tv unplug,replug tv back like about an hour later,by letting the tv resetting itself back to the factory setting.The tv now should be working again.Not than the tv have power supply board problems and causes.That the board,where the power a/c cord plug into it.Try website like Ebay.com to buy a refurbish power supply board for the replacement.
Posted on Feb 05, 2011
6ya staff
SOURCE:
My Foxtel box will not turn on, I checked batteries not that.
Box won't come out of standby - Support - Foxtel
https://www.foxtel.com.au/support/tv/troubleshooting/.../foxtel-boxes/standby.html
Reset your Foxtel box by switching the power off at the socket, then pull the power cord out from the back of the box. Leave the power disconnected for at least 30 seconds. Plug the Foxtel power cord back in and switch the power on. Your Foxtel box should turn on and light up.
Foxtel box has no lights - Support - Foxtel
https://www.foxtel.com.au/support/tv/troubleshooting/.../foxtel-boxes/no-lights.html Step 1: Check the power cord is connected securely. Check the power cord is secured tightly at the back of your Foxtel box and at the power socket. If your remote isn't working, troubleshoot your remote click here.
Solved: Box will not turn on - Foxtel Community - 30431
https://community.foxtel.com.au/t5/Foxtel-TV/Box-will-not-turn-on/td-p/30431 My box is frozen with the green light on. Have tried unplugging and leaving for a couple of hours but it still will not turn on whether using the remote or the button ...
Solved: Foxtel wont turn on - Foxtel Community - 10049
https://community.foxtel.com.au/t5/Foxtel-TV/Foxtel-wont-turn-on/td-p/10049 Does the box stay in standby mode - the light staying red instead of turning green? If the orange light is flashing on the box when you use the remote then the ...
Foxtel Now box start up issues - Troubleshooting - Foxtel Now
https://www.foxtel.com.au/now/support/troubleshooting/box/startup-issues.html Troubleshooting and tech help for your Foxtel Now box if it does not boot up successfully or won't turn on.
May 11, 2018 | Televison & Video
My 40" Soniq tv wont turn on?it was working this morn.I switch it of abouut 5 hours ago and ive tryed turning it on for about an hour?Ive unplugged tv from power board for 10 mins,plugged it back in and it...
Are you tech savvy?...I can give you some voltages to test if you're able to do that, if you aren't then you have 2 choices, take it somewhere to be serviced but expect to pay between 75 and 100 dollars an hr for tech time plus parts or replace the set with a new one.
Feb 11, 2018 | Televison & Video
My Coby LEDTV-2426 24 No Power
Switch off TV, switch off power, remove plug and wait for 48 hours and retry. If problem persists, I suggest it is better to refer it to a qualified service technician, since the back cover has to be opened for investigation/rectification.
Aug 19, 2012 | Coby LEDTV2426 TV
My acer Aspire 3500 wont turn on. It was fine a few hours ago but now wont boot. I keep getting the acer picture featurning the f2 set up and then the screen turns blank with a white flashing - in the left...
if you activity lights on, try connecting to an external monitor or modern flat screen tv. if the screen is flashing then it is probably a screen issue. eg the invertor r screen has failed.
Jul 23, 2011 | Computers & Internet
Sony triniton KV- XG29M30 WONT TURN ON
I had a similar problem a few years back . I purchased a new on/off switch from Sony and that seemed to fix things.
Alleluia
Jan 05, 2008 | Televison & Video
Vizio P50HDTV20A 50 in. Plasma HDTV Logo
231 people viewed this question
Top Vizio Televison & Video Experts
Tony Nguyen
Tony Nguyen
Jerry Greenberg
Jerry Greenberg
Are you a Vizio Televison and Video Expert? Answer questions, earn points and help others
