Yours is a 2 speed motor. Does it spin in 2 different speeds. If so, then it most likely is designed with only to agitate in 1 speed. If it only spins in one speed, then your motor is defective
It could have gone out of balance. See if the drum looks off center and center it if necessary. Turn it off and back on to reset the switch. If that doesn't work, try pressing on the lid either 2/3 of the way back on the right or all the way back on the left (depends on the model -- try both) and see if it starts. If it does, I would suspect the lid switch.
sounds like a transmition problem. does the noise happen when it goes into spin on the other settings? If no noise in the spin cycle on the other setting, then it sounds like a the gears in the transmition internally when bad for the agitation.
You most likely have a broken coupler between the motor and gearcase.
You can buy the part for about $10 or have someone come out and replace it for about $150-200.
If you will post the complete model number from the the washer so I can see which style cabinet you have, I will try to walk you through the repair. It isn't very complicated if you are handy with home repairs.
With the age of the machine it probably just needs a coupler, but it could also have a problem in the transmission or basket drive that has caused the failure.
