Televison & Video Logo
Posted on Feb 06, 2011
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
Can't get my westinghouse tv to recognize dish network
  • Anonymous Feb 08, 2011
    Are you not getting a picture or is the tv not taking commands from the DISH remote?
    Daniel Busa
    DISH Network Customer Service
Anonymous
Level 2:
Novelist:
  • Expert 123 Answers
  • Posted on Feb 11, 2011
Anonymous
Expert
Level 2:
Novelist:
Answers
123
Questions
0
Helped
77685
Points
165
Happy to help get that fixed right away!
You mentioned that your TV is not recognizing the DISH Network signal, since wedo not know how many TV's your receiver is able to support, or whether it's theTV1 or TV2 having the issue I will address them both.
The first thing we want to do is ensure that all connected components arepowered on (VCR, DVD Player, etc.). Check what channel or input your TV iscurrently on by powering the TV off then back on and noting the channel orinput that appears on screen when the TV is powered on.
If TV1:
Check what type of cable is used to connect the TV to the receiver. If you areusing a Coax Cable to connect the receiver to TV1, check the receiver'sback panel for the output name. If your receiver has a "TV CH 3/4Out" (non-ViP Receiver): Tune TV to channel 3 or channel 4,if it has "Home Distribution" output (ViP Receiver): Tune TVto channel 62 or 75. If using non-Coax (RCA, Component, orHDMI) to connect receiver to TV1, cycle through the inputs until pictureappears; most TVs have a "TV/Video", "Input", or"Source" button. If the issue persists, check that theconnections between your DISH receiver and your TV are secure then reset thereceiver by unplugging it from the outlet for 10 seconds then plugging it backin. If not fixed then connect another component (VCR, DVD Player, etc.) to thesame TV, using same cable, same input, and same channel to see if it works. Ifit works with the other component then call us at 1-800-333-DISH (3474) foradditional troubleshooting, if it still doesn't work with the other componentthen the cable should be replaced.
If TV2:
Access "Modulator Setup" from TV1 by pressing the menu button(on the top left of DISH remote) then pressing the numbers 6-1-5. Tune TV2 tothe channel that appears under "TV2 Out" on screen. If stillno picture, verify the mode (air or cable) that TV2 is on. Then change themodulator setup to match this mode (air or cable). After changing modulatorsetup, tune TV2 to the channel that appears under "TV2 Out" onscreen. Check that the connections between your DISH receiver and your TV aresecure then reset the receiver by unplugging it from the outlet for 10 secondsthen plugging it back in. If not fixed then connect another component (VCR, DVDPlayer, etc.) to the same TV, using same cable, same input, and same channel tosee if it works. If it works with the other component then call us at1-800-333-DISH (3474) for additional troubleshooting, if it still doesn't workwith the other component then the cable should be replaced.
Phillip Chang
DISH Network Customer Service Representative
  • Anonymous May 28, 2012
    That didn't work. So I took it to input mode, the four choices were 1. Cable, 2. HRC, 3. IRC and 4. Air. I choose 4. Air, scanned and #60 came up. problem solved.
1 Related Answer
Anonymous
  • Posted on Dec 25, 2010
SOURCE: i need the code for westinghouse tv
I am having the same problem with direct, let me know if you find a solution?
How to pair Westinghouse Remote RM-21 with Dish Network
I believe that dish has it's own type of remotes and the remote that you purchased is specifically compatible with your tv and not necessarily the Dish box. This would explain the difference in the code lengths. So, you would need to call dish and ask them what remote's are compatible with Dish. Thank you.
What is the remote code for Westinghouse TV's
beaker60,
I would need to know the model remote to provide exact codes for that TV brand, but I can provide some general codes.
White Westinghouse TV: 500, 781, 816
You can check out this link for more information. Choose the receiver model that matchs yours and it will show you the codes!
http://www.dishnetwork.com/SupportSection/remote-setup
Tommy Faust
DISH Network
5helpful
Westinghouse - 60" Class / 1080p / 120Hz / LCD
There is a method called a Power Scan this method allows you to search for all possible codes. Try this until you reach a code that carries all of the functions desired. If the TV mode button starts flashing rapidly during this process you have exhausted all possible codes.
Power Scan
1.) Hold down the clear "TV" button on the remote for four seconds, then press 500 pound ( #)
2.) Hold down the clear "TV" button on the remote for four seconds, press the big power button once.
3.) Press the channel up button once per second until the TV turns off then press pound (#).
Daniel Busa
DISH Network
Customer Service
1helpful
Hello! I wanted to give you a few more codes that you may not have tried. I also wanted to give you the instructions to the power scan, which will scan the TV for the correct code. I hoep this helps!
Codes:
500
795
719
Power Scan:
1. Hold down the Clear TV button until all lights at the top of the remote light up
2. Press the red TV POWER button
3. Press and release the up arrow on the remote about once a second until the tv turns off.
4. When it turns off, press the # (Pound) button
5. Try powering the tv on/off, and try the volume. If one or more of these functions do not work, start over at step 1 again.
Becki Barned
I have dish network and need the remote code from the tv to activate the dish remote to change the channels, etc. And how do i program the remote to work with the tv
Hello! My name is Becki Barned with DISH Network. To program your remote, just follow these simple steps:
1. Hold down the clear TV button until all lights light up at the top of the remote
2. Punch in a 3 digit code (provided below)
3. Press the # (POUND) button
4. Try powering the tv on/off, and the volume. If one or more of these functions do not work, start over from step 1 with a different code
500
795
816
Becki Barned
I can get my dishnetwork remote to program for the volume nor to turn it on or off help me please the model #w32001
We would be happy to help you with that.
Step 1:
Press and hold the TV button until all mode button back lights come on, then release.
Step 2:
Use the number buttons to enter the device code corresponding to your Westinghouse TV. Potential codes for White Westinghouse are: 500, 719, 664, 555, 674, 659, 670, 672, 641 and 573. Then press the pound (#) button. If the code entered is valid for the remote, the mode light flashes three times. Your DISH Network remote should be able to control your TV. Thanks for being a valued DISH Network customer.
Phillip Chang
My tv went off. My cable (dish network is still on, and the power to the tv is still on, you can hear the program, but the screen is blank. But.. if you turn off the tv, then turn it on, you see the tv...
Hello, this is Dan with DISH Network, try this link it should resolve this.
http://www.dishnetwork.com/SupportSection/video
Daniel Busa
How do I hook this TV up to Dish network. friend gave me tv no manual
Hello myname is Mike Houston of DISH Network and I see you're trying to connect theWestinghouse LTV to the DISH Network. There are easy steps to get it connecteddepending on the receiver you have. I will send a link http://www.dishnetwork.com/SupportSection/setup-receiver-totvthat will help with these steps.
White westinghouse tv code for remote control? And the procedure to program it.
pepelule
Here are the codes for your White Westinghouse TV: 719, 500, 659, 664, 670, 672, 674
I have also included the instructions for programming the remote to your TV. I hope this helps.
  • Remotes: Basic (Television Only)
    1. Turn the Television On
    2. Press and Hold the TV Power button for three seconds until the LED flashes
    3. Enter the three-digit code using the buttons on the number pad.
    4. Press OK. Note: The LED will flash three times.
    5. Test functionality with the TV
    6. Return to Step 2 if the remote is not able to turn the TV On/Off, change the volume and mute the television.
Ray Calo
DISH Network
Top Westinghouse Televison & Video Experts
Grand Canyon Tech
Grand Canyon Tech
Paul Bade
Are you a Westinghouse Televison and Video Expert? Answer questions, earn points and help others
