Heating & Cooling Logo
Posted on May 15, 2017
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
I have two split system Conia rev. cycle air cons models CA30003. Both have "died" within a month of each other. They are just over 3 years old. The cool cycle just switches itself of and blows normal temp air. I switch it off for 20 minutes or so, switch it back on amd it cools for another 1/2 hour before blowing normal temp air again. Parts are not available (so the service guy tells me),. Firstly, any ideas as to the problem. If so, where can I get parts if they are required? I'm in Australia Thanks
  • Chris Wong
    Chris Wong Feb 11, 2019
    Hi lin2367,
    I have the exact same issue of yours. I want to know whether you have found the solution. Thank you.
Andy
Level 3:
Loyalty:
Visited the website for 30 consecutive days.
  • Heating & Co... Master 572 Answers
  • Posted on Feb 11, 2019
Andy
Level 3:
Loyalty:
Answers
572
Questions
0
Helped
209462
Points
1498
You may have dirty coils
Thomas Woodburn
Level 3:
  • Heating & Co... Master 2,638 Answers
  • Posted on May 15, 2017
Thomas Woodburn
Level 3:
Answers
2638
Questions
Helped
1250648
Points
7008
It's likely low on refrigerant and freezing...turn it off, coil thaws , cools for a short time and freezes up again. Chances are the leak or leaks are at the flares where the copper connects to the unit. Need leaks repaired and systems recharged.
If you need further help, reach me via phone at https://www.6ya.com/expert/thomas_092728000e6acb79
5 Related Answers
Sea Breeze
John Tripp
  • 4656 Answers
  • Posted on Jul 06, 2009
SOURCE: Will not cool properly.
You have either a faulty thermostat, dirty condenser and evaporator or a faulty run capacitor. Need to service soon before the compressor is damaged. Sea Breeze
Anonymous
  • 81 Answers
  • Posted on Aug 30, 2009
SOURCE: blowing out warm air
This could be a refrigerant leak. Before you call out a service technician, clean the filters and then try to see if it works. If it doesn't then get the unit serviced.
Hope this helps
I take the time to answer your questions, so please rate me.
Mat
Anonymous
  • 534 Answers
  • Posted on Aug 31, 2009
SOURCE: air conditioner doesn't blow cold air. Continues
If the a/c fails to continue to blow cold there could be a few problems you can look for. First once you activate the system check to see if the compressor kicks in. You will hear the compressor humming . Once the a/c quits cooling go and see if the compressor is still running. If its not running its probibly gone into thermal overload (compressor overheated). If that is the case then you need to check to see if the coils are icing up if they are icing up then the problem is with 1) air flow restriction filter dirty, coils dirty simple repairs there replace filter, clean evaporator coil with a coil cleaner that can be purchased at a home repair store cleaning the condensor coil the same. 2) system is low on freon in which case the system will need to be recharged. Also, If you have a digital thermostat replace the batteries that may also be of some help. Good Luck on repairs
Dave
Anonymous
  • 540 Answers
  • Posted on Dec 02, 2009
SOURCE: Conia 3 HP, 5 yr old air con/ condensation from wall unit
NOW, THE EVAPORATOR COILS NEEDS CLEANNING OR THE DRAIN LINE PLUGGED,OR JUST CLEAN THE FILTER.
Anonymous
  • Posted on Jan 12, 2011
SOURCE: need a conia airconditer remote control here in
i had the same problem and i managed to find a universal remote control from JARCAR Electronics. Model of the remote: Digitech AR-1729. It doesn't list Conia as compatible but I managed to gain control of the aircon using the code: 291. For some reason when you press the power button on the remote, it's like your double pressing the on button so the aircon switches on and off quickly. You need to press the power button on the remote quickly and move it from reception before it powers down the unit again. At least I have control of the aircon again and I don't have to put up with these humid hot days in melbourne... Good Luck.
What is the best size kw. ANY BRAND Air Con is Equivalent to suit Air Con : Conia Air Con Model : CA242 S/N:ca24220970353
KW is not the number that you need to be concerned with. The newest rating for HVAC is called SEER. If yours is older it might be listed as TON.
1helpful
Have a Silverstorm split aircondtioner lost remote cant get cooling in summer periods.
split air cons come in both configurations and are mostly in the last few years with inverter systems
you can get cooling only or cooling and heating systems
some brands only have the cooling only on the smaller units ( 8000 btu units)
Is Conia air conditioner CA24001 split system reverse cycle I cannot get heat?
Sounds like either bad reversing valve or to get you going during the summer someone may have wired it to stay energized all the time which would have been a thermostat problem.
Conia split system operating manual
Not sure if this is what you are looking for. A Make and Model would be a great help in finding the information that you are looking for. So we at West Palm Beach Air Conditioning would love give you a hand.
Manuel:
https://highcongtana.files.wordpress.com/2015/10/conia-air-conditioner-manual-ca24003.pdf
RETAIL PRICE FOR ONIX REVERSE CYCLE SPLIT SYSTEM
contact shops that install units and get quotes. retailers generally have contractors that will give quotes for installation on new units.
Please help me reset conia split air con ca2422
If you need to reset a pressure switch...then the refrigeration system needs to be checked. High or low switch looks like about a 3/4 inch Diameter plug with 2 wires & a red manual reset switch in the middle.
What is an error 3 in conia split system
shut down the energy alimentation for 2 minute ,but if the defect persist error it show again
2helpful
Top Heating & Cooling Experts
Paul Carew
john h
