Question about Toshiba 65HX81 65" Rear Projection Television
Blinking Yellow light on a HD 65" DLP Toshiba TV
I switched the tv to power-save mode last night, tonight i turned on the TV and the yellow light blinks in cycles of three ... it has been an hour and the TV hasn't turned on yet ...HELP
  • edward Jun 07, 2013
    I have a similar problem with my 72hm196 Toshiba DLP. When power on the blue light is always on. But the yellow light is blinking and cycle continuously. I can hear the clicking sound when it recycle and the yellow light is on. Can not shut down the TV except unplug the power.
I have a 56 inch tohiba DLP (56 HM 195). Replaced the bulb for the second time this year. last time only lasted 3 months. TV is tough to turn on. When I get it to turn on, and then shut it down, the yellow light blinks constantly for 5-7 mintues. Then it shuts down completely. Is the set overheating? There is nothing in the manual that speaks to this issue. thank you
Posted on Aug 15, 2009
    Champion:
  • 317 Answers
Unplug all nite.
Posted on Aug 03, 2008
My maytag dishwasher dosnt work. the delay light 2,4,6 lights just blinks. I would like to know the reset code to see if i can do a cycle run.
I pressed heavy wash 3 times and then start to make it perform a field test. It tested fine, but it stuck at 61 minutes for an hour while I was testing auto clean. Another thread indicated that the controller cable interface was getting moist.
Dec 05, 2014 | Maytag 24 in. MDB5601AWS Stainless Steel...
Wont turn on but yellow light is flashing
I followed the steps at the following link and it worked for me. I have a 2007 Toshiba Regza 42HL67, but the firmware applies to many models as documented in the readme file at the location found via the link below. I used a 1gb SD card formatted FAT16, copied the unzipped files and folder to the card (wasn't sure if it required the top level folder or only the files under the top level folder so I copied both to the root of the SD card), unplugged the TV, inserted the card, plugged in the TV, waited 2.5 minutes, unplugged the TV, removed the card, plugged in the TV, yellow light flashed 3 times and went out. I turned on the TV and it has worked normally since last night.
http://www.benjammin.net/www/pages/techtips/Toshiba-Regza-42HL167.html
Jul 23, 2010 | Toshiba REGZA 47HL167 TV
Maganavox flat screen tv no pic, red light blink codes...
Those blinks are fault codes. To know more visit the site linked here. http://electronicshelponline.blogspot.com/
Mar 25, 2017 | Televison & Video
37MF321D/37 TV turned off last night. This morn, won't turn on
Please read these replies to the same problem. A new power board costs around $284.00..
http://www.fixya.com/support/t465280-magnavox_37mf321d_37
Jan 01, 2010 | Philips Magnavox 42MF521D/37 Television
My tenplus year old Toshiba 32" TV is stuck in standby mode
You have an old tv so the best problems are bad capacitors and bad grounds. Have someone pull the board and search for high voltage caps [160volts or 250 volts] with 1 to 4.7 microfarads. Should be two or maybe three and check all grounds. If the 4 amp fuse is good than the above will save your TV.
Sep 24, 2009 | Toshiba 32A33 32" TV
My toshiba 42HL167 won't turn on
Try this fix from the toshiba website. Q. I have no picture or sound, but I have a blinking power light?
Models: LCD-2007
REF:FAQLCD00090
1. Try resetting the TV by disconnecting the power for 30 seconds and then plugging it back in. If this has no
effect, try moving the TV to a different power outlet that has been tested and is known to be good.
2. If your unit continues to fail, please contact our Customer Solutions Department at 1-800-631-3811 Monday
through Friday, from 8 a.m. until 7 pm CST for a local Toshiba Authorize Service Station Hope this helps you with your problem.
Feb 27, 2009 | Toshiba 42HL167 42 in. LCD Television
Mitsubishi WS-55513 won't power on.
there is an electronic problem inside the tv you shoud go to an authorized service because the power supply to this tv it is in protect mode somehthing hapened inside and need to be repair
Dec 11, 2008 | Mitsubishi WS-55513 55" Rear Projection...
42hl67
I had lcd 42" over a year it is working find before , but now it has very dark picture
can y help me to find out what is a problem and how much to fix?
May 01, 2008 | Toshiba 42HL67 42 in. LCD Television
Sony FD Trinitron WEGA KV-36HS500 blinking red light 6 times
My Sony KV36HS500 Trinitron is doing the same thing. Last night the next street over was hit by lightning. The "7" blink pattern was happening, so like the manual stated, unplug it for 4 hours. Which I did. The t.v. is back up and running fine. It's a nice t.v., better than the plasma I paid over a grand for, that's already shot. It's a good t.v. and good that Sony put in the stand by protection to prevent the t.v. from dying an unnecessary young death. Patience, don't rush it, unplug the t.v. and leave it sit. Also, don't use a power strip, that was my mistake, and unplug your t.v. if storms are in the area, I was too lazy to and now I had to deal with this, in 8 years, only twice did this happen. I'd buy another one tomorrow if they still made them.
Apr 07, 2008 | Sony FD Trinitron WEGA KV-32FS120 32" TV
Toshiba 65HX81 65" Rear Projection Television Logo
2,488 people viewed this question
Top Toshiba Televison & Video Experts
matt martin
matt martin
Are you a Toshiba Televison and Video Expert? Answer questions, earn points and help others
