If you want the unlock code immediately, then i would like to recommend the site Unlocking4U where they can get you the code as soon as possible.
Unlock Phone Unlock Codes Cell Phone Unlocking Service Online Unlocking 4
SOURCE: W580i - Problem in Unlocking the Phone
Press the following sequence when your phone is on: Left(joystick), *, * left.
Either a menu will pop up where you have to pick NCK or you will be able to directly enter the unlock code.
SOURCE: my nokia N73 black from UK needs to unlocked
Your Nokia Master Code: 2104565640
Thanks you very muck for your Questions.
SOURCE: Restriction Code for NOKIA 1680classic
Hi!... It means your phone is locked... You have to unlock it before using it...
SOURCE: I want to flash my mobile please tell the software
Firstly try to download this http://www.driversdown.com/drivers/Nokia-Phoenix-Service-Software_92760.shtml
Secondly download
6300files
And install it in your PC..Disconnect all usb devices.
Now connect the phone with usb data cable without power on the phone to PC.Open Nokia pheonix...Click to "FILE" and select "open product" Choose 6300 rm217.Next Click to "Flashing" and then open "FPS-8C FLASH " after opening this just click to "Close" button and again click to "Flashing" select "FIRMWARE UPDATE" NOW you can select the firmware version as well as the product code at the top right which is showing a small browse window.Remember if the product code of the particular is not there just select the highest one.
After loading ..Click to "Dead phone" and again press to "REFURBISH"
Wait until a message shows that "PRESS POWER BUTTON" Press it and wait until the phone automatically switch on.
Good luck.......
