Question about HP Pavilion dv6835nr Notebook
On my HP Pavillion dv6835nr laptop, the color is messed up. The areas that should be white, are mostly green/torqoise, with white ting to things. The edges of the green areas are quivering. The other colors in the task bar, tool bar and other places are not correct. When I try to change or correct this in appearances, it makes changes, but does not correct this problem. When the computer was last shut down, everthing was fine. This problem showed up when it was booted up the next time. It did this 3 or so times before, but I was able to get it back to normal, but did not know why it came back, Is this a problem with the LCD, screen, mother board, or other things?? I did some research that gave some of these things as possible problems, along with some other possible things that it could be. Does this sound like a hardware or software problem?? Looking for any answers as to what this problem may be. Thanks
  • HP Master
  • 20,706 Answers
These HP posts are always HUGE walls of text.
that is ok but wow.
but then no photos of MESS?
must we guess that?
but if your LP has an external 15pin Video jack (d-shell type)
that uses any external display seen on Desktops
you can find out this your self
if the external works, then the internal hardware is bad.
easy no?
HP.com shows the 1 VGA (15-pin)
jack there and the hot function key that ENABLES IT.
Posted on Mar 10, 2017
3 Suggested Answers
6ya staff
SOURCE:
Anonymous
SOURCE: HP Compaq Presario V5000 LCD Problem
I have the same problem. I thought the problem was due to a loose cable so I opened the computer up only to find out the cables are all good. I still haven't found a solution
Posted on Sep 08, 2008
Anonymous
  • 520 Answers
SOURCE: HP Pavillion won't boot
has windows been registered.
if so your gonna have to reinstall windows.
make sure os disk is in cd tray ..boot up...choose install (not repair) sys check says os already installed continue install or repair...at this point choose repair..this way any files or downloaded programs wont be lost.
Posted on Jan 14, 2009
Pavillion dv6835nr MGR is missing DVD drive does not work
just download winsetupromusb 1 beta 0 to make usb bootable no need dvd drive
Mar 23, 2014 | Computers & Internet
My picture has a green tinge to it. It is most noticable in the balck and white broadcasts. I know the lamp is close to needing replacement because it takes longer to brighten up. I was going to order a...
I have found this in the owners manual which is adjustment to grey scale when there a green ting. this may help. White Balance page 36
Color Temp 4 settings page 35
Iris Settings page 34
Nov 02, 2010 | Sony KDS-50A2000 50" HDTV
I just changed my o.s from vista to win7 and i have hp dv6835nr but cant get any drivers online, how should i load drivers on my pc now
HP does not plan to provide Windows 7 drivers for your model. It is suggested you revert back to Vista or XP and then run the windows 7 compatibility check BEFORE trying to switch.
Apr 12, 2010 | HP Pavilion dv6835nr Notebook
Green tinged photos on photo paper normal color output on plain
Assuming a 2 cartridge system, and you want B&W or sepia, pull the color cartridge and print away! Works for my HP DJ 5440.
Jun 30, 2009 | HP PhotoSmart 7550 InkJet Printer
Color are messed up white is pink
Is it messed up if you plug in an external monitor? if no then something is messed up in the internal connection in the computer and you would need to take it apart and replug in the video cable on the back of the monitor panel.
Jun 14, 2009 | HP Pavilion dv6000z PC Notebook
I have a hp pavillion S50 15in crt and it has a green hue to the screen.
There are a few things that can cause this. The two most frequent: (a) Has the monitor or computer been moved? The connector may be loose or slightly "off" of the port on the video card.  (b) If that's not the case, does it happen all the time? It's possible that one of the color 'guns' is off or malfunctioning - which means, essentially, a dead monitor. A 15" CRT just isn't worth fixing these days.  The little buttons beneath the monitor, unfortunately, do nothing for color adjustment - just brightness, contrast, and the usual positioning controls.
Jan 13, 2009 | HP Pavilion S50 (White) 15 in.CRT...
Acer Laptop TM240 , display has green tinge....
This is one of two things.
The first is that the color settings in the advanced section of your display properties has been altered.
The second and unfortunately the more likely is that your lcd screens back light or cfl (compact fluorescent lamp) has began to fail, usually due to age.
If this is the case you can either replace the entire lcd panel or just the cfl. Changing the lcd panel is fairly straight forward, but changing the cfl while it is the cheaper option it is a much more technical job to complete.
Jul 02, 2008 | Computers & Internet
Hp pavillion dv6835nr dvd player
Try this, put a DVD movie in the drive, then open windows explorer (Right click the start button, click explore) then see if you can read the DVD files on the DVD.
If you cannot browse the DVD then the DVD optics of the drive have failed and you will need to replace the drive.
May 17, 2008 | HP Pavilion dv6000z Notebook
Too much yellow in picture
The problem with the set is that the blue gun has gone weak, and not emitting at par with red and green guns in your picture tube. Turn of the blue screen and get the grainy display on the screen (detach the cable) and enter into service mode to fine tune until you get a perfect or black and white grain pattern.
Dec 19, 2007 | JVC AV-27230 27" TV
Hp psc 1210 all in one colour problem
Sounds like Color cartridge problem...
Colors on the cartridge are mixed together
Dec 05, 2007 | HP PSC 1210 All-In-One InkJet Printer
HP Pavilion dv6835nr Notebook Logo
101 people viewed this question
Top HP Computers & Internet Experts
Ekse
Thomas F. Schneider
Alun Cox
Are you a HP Computer and Internet Expert? Answer questions, earn points and help others
