LG 47 in. Flat-Panel LCD HDTV Logo
Posted on Feb 06, 2011
47 inch LG LCD TV picture setting goes to VIVID mode automatically after about 3 to 5 minutes of viewing. This is very annoying. I have manually reset the picture mode with the remote constantly. If you have any suggestions, it would be greatly appreciated. Thanks, Al
5 Related Answers
Anonymous
  • 88 Answers
  • Posted on Jan 08, 2009
SOURCE: LG 22" HD ready LCD Picture mode problem
This problem is going to be a bad main board (sometimes called digital board). Hope this helps.
Andrew White
  • 41 Answers
  • Posted on Mar 13, 2010
SOURCE: "47 LG LCD TV automatically turns off by itself"
Your Power Board is going bad. I think this set has a one year warranty on parts.
David Low
  • 458 Answers
  • Posted on Mar 22, 2010
SOURCE: can i get my 47 inch lcd tevion screen replaced
Yes you could get the screen replaced, however the cost of this now-a-days is almost equal if not more expensive than purchasing a new TV. It is not always economical to have the screen replaced, it is maybe more worthwhile to think about buying a new one instead.
Anonymous
  • 1654 Answers
  • Posted on Mar 24, 2011
SOURCE: hello my whole screen is
It can be fixed, but the cost is high and if it were me I would spend the money on a new set instead of repairing an old one. The screen for this runs around $525.00 for a used one, up to $900.00 for a new. Then you have a shop charge of aournd $100.00 and up for the labor.
Anonymous
  • Posted on Dec 13, 2011
SOURCE: lg 47 inch tv sound
I have the lg 47 lcd and i had the same problem for about 1-2 months ,but out of the blues the sound just got really louder ,i think the speakers broke in and it the sound normalized.But my tv sounds great now , my kids even asked me if i did something. Maybe just give it a little time.
How do I turn off the closed captioning?
Page 49 of User Guide:
SETTINGS ? OPTION ? Caption View captions when the TV station provides captioned programing. Program captions work only on digital/analog broadcasts or external input. Change Caption to On or OFF. If On, then select caption settings. • Mode CC 1-4 (Closed Captioning) / Text 1-4 : Displays the audio portion of a TV program as text on the TV screen. CC1 is the most common mode in use. Field 1 data channels: two Captions (CC1, CC2), two Text (T1, T2). Field 2 data channels: two Captions (CC3, CC4), two Text (T3, T4). Service 1-6 : This is only available for the digital broadcasting system.
If you do not have a User Guide or other manuals for your television, please download them here:
http://www.lg.com/us/support-product/lg-47LS4600#
2answers
My tv image goes off while watching tv,I do have audio but no image.
LG 42LS5700 - LG.com
www.lg.com > Home > Support > Product Support
LG ElectronicsTV/Audio/Video; TVs; 42LS5700 ... TV Support Landing Page - HDTV/Netcast/webOS 1.0/webOS 2.0 ... Adjusting Picture Settings - webOS 2.0 Video ... quality and convenience of complimentary shipping when buying directly from LG.com. ... Curved TVs · 22 Inch to 29 Inch Class TVs · 32 Inch to 39 Inch Class TVs · 40 Inch ...
Amazon.com: Customer Reviews: LG 42LS5700 42-Inch ...
www.amazon.com/LG-42LS5700-42-Inch.../B006ZH...
Amazon.com, Inc.LG 42LS5700 42-Inch 1080p 120Hz LED-LCD HDTV with Smart TV (2012 Model). byLG. Size: 42-Inch ..... images are nice and crisp when viewing HD content.
Widescreen TV Black Screen - Repair LCD LED PLASMA ...
? 3:41
https://www.youtube.com/watch?v=RbZncfiOXQA
Jul 13, 2011 - Uploaded by FixItUrselfDummy
Fix your tv with black screen blinking light, popping sound noise. ... Watch QueueQueue ... TV Black Screen - Repair LCD LED PLASMA - Problems SONY LG .... I have a 60 inch samsung DPL tv how can I stop the humming or ... What do I do if my tvturns on but its just a black screen so sound no picture?.
LG model 47LG50 47" HDTV
you can get cheap replacement boards for this tv via ebay,...........good luck,...
cheers
1helpful
Bottom half of screen goes black
This is because full pixels of your TV is not getting invoked at the beginning .If you are able to view the picture as normal after 1 or 2 minutes, its fine.Else you need to call to service center and get this problem fixed.
2helpful
Picture setting reverts to Vivid
LG replied to my enquiry abd apparently the TV was in store mode. Just required a factory reset,...seems to have done the trick !
4helpful
TV PICTURE SETTINGS REVERT BACK TO DEFAULT LG 32PG6000
hi it sounds like when tunned in tv it was tunned in shop mode.
do a factory reset and choose home when installing
Picture not centered on my philips 47'' lcd tv
NOTE:(Edited and copied from another thread on Fixya.com, c7carl)
Picture is not centered on monitor leaving a 2 1/2 inch; black border on Philips LCD
By dmorrow54 on Nov 13, 2007
Again, nothing in manual for Philips LCD will correct the fact that the picture in HD-D mode will not center. The picture runs off the monitor on the left (facing the monitor) with a 2 1/2" black border on the right (facing the monitor). Using the format button on the remote of directional arrows will not correct the issue. The wide-screen/ full-screen function with format does nothing. Moving into TV mode, the format function works to display screen in several ways 4:3, 19:2, super-zoom, wide-screen, full-screen. Help, please. posted 3 years ago
Guest
  • Rank: Guide
  • Rating: 0%, 0 Votes
I have a Philips 30 inch LCD and solved the problem by using the circular arrow button on the TV remote. Pointing it at the TV and clicking "right" (3 o'clock on the button), the picture moved right. Same thing on for "left". Worked for me.
Add a comment
    • c7carl
    • 5 minutes ago
    WOW! It works!! The picture on my Magnavox (aka Philips) 37MF321D had shifted to the right. I figured I had a big repair bill coming up soon. But hey! Just used the TV remote as described by "Guest', and re-centered the picture to the left. Wallah! Thanks ""Guest" whomever you are! Reply
    Posting advertisements, profanity, or personal attacks is prohibited. Click here to review our Terms of Use.
    Comment:
4helpful
2answers
Lg Plasma Display settings keep switching
When you boot up your tv for the first time, you get to choose between home and shop-mode.
In your case, he TV is set to "shop-mode".
Then it will go back to factory settings after 5-10 minutes. (so that customers won't mess up the settings all the time)
So change the settings from shop to home, and your problem is fixed!
17helpful
3answers
LG 32'' LCD TV aspect ratio self switching
I have an LG LCD TV with the same problem.
The solution is to go to
MENU
OPTIONS
FACTORY RESET
And select HOME rather than STORE on initial setup.
Mine was set to store as it was a display model.
That means that whatever picture setting you make they will reset after 10 minutes.
Grand Canyon Tech
Grand Canyon Tech
Kolbrun...
