Nec NFL-1065 front loader washing machine. PFE error code shows when machine stops before last spin cycle.Nec NFL-1065 front loader washing machine. PFE error code shows when machine stops before last spin cycle.
I dont have data on this specfic machine but from experence id say check the drain pump for blockage or something jamming the pump but reamber there is water still in the tub when you check this i reccomend if you have a shop vac pull the water out through the drain hose before checking the drain pump
When you start your machine is the water just go stop go stop,
Just wait for the machine to display an error code on the wash progress lights and beeps constantly.
It could be the Rotor Position Sensor, out of balance switch or lid magnetic reed switch.
Your error code will determine this. Is your machine beeping & showing a weird pattern of lights on the wash cycle, It is displaying an error code, To read this error code you start at the red spin light & work to the left only add up the lights that are on. Red spin light = 1 2nd rinse light =2 1st rinse light =4 last wash light=8 4th wash light=16 3rd wash light=32 2nd wash light=64 1st wash light=128
When you start your machine is the water just go stop go stop, Just wait for the machine to display an error code on the wash progress lights and beeps constantly. It could be the Rotor Position Sensor, out of balance switch or lid magnetic reed switch. Your error code will determine this. Is your machine beeping & showing a weird pattern of lights on the wash cycle, It is displaying an error code,
Red spin light = 1
2nd rinse light =2
1st rinse light =4
last wash light=8
4th wash light=16
3rd wash light=32
2nd wash light=64
1st wash light=128
• The washer will stop during
spinning .
• Spinning is insufficient.
Error display PFE • Is the filter of the drain pump clogged? • Is the drain pump operated? • Did you use the proper amount of detergent? • Is the drain hose placed higher than 1m above floor?
Bosch washers come with built-in sets of error codes used to diagnose and correct common problems. The E27 code isn't often listed in Bosch manuals but relates to the washer door lock
The E27 error flashes on the washer LCD screen and stops the current load. Unplug your washer for 30 minutes and then plug it back in to reset the code.
Open and close the door two or three times to reset the sensor. Sometimes the door has been closed too hard and the sensor reading fails.
Can you tell me what point of the Wash Cycle the Cycle Status LED is in when you error out with the LL error code?
I believe it will be in the Spin Cycle of the wash cycle.
You could try a Quick Spin test and see if the wash basket will spin up to 850 RPM with no laundry in the Wash Basket.See Page 14 of the Service Manual and see if the Wash Basket will spin up to 850 RPM.
You could also check the TDS for proper range of motion using the SM or this typed out process. Tub Displacement Sensor Diagnostics check. It is possible the Tub Displacement Sensor may have failed try this check which is in the Troubleshooting guide stored in your washer console or refer to the SM.
a. Enter the Service Mode by pressing and holding the Enviro Plus and Spin Only keys for three seconds or the display reads “00”
b. Press the Super Wash key display reads “in”…something like that.
c. Press Delicates the Display will show “UC” (Unbalance Closed).
d. Push tub to the back right corner of the machine the display should change to “UO” (Unbalance open). Release tub and the display will show “UC” (Unbalance Closed).
e. Press Hand Wash.
f. Pull tub to the front left corner while pushing the tub down the display should change to “UO” (Unbalance open). Release tub and the display will show “UC” (Unbalance Closed).
If you fail this test it would be time to remove the machine front cover check if the TDS sensor has fallen of its mounting position between the Tub and the washer frame.
If your machine is a FAV6800A to FAV9800A here is the Service Manual. If it one of those machines I suspect a possible clutch malfunction. See this postfor what is involved to do clutch maintenance or replacement.
Do you have any error codes to the display if it's a FAV6800A such as dC or uC unbalance codes.Is the wash tub banging around on Spin Cycle of the Wash Cycle? ……Rich
Is your FAV6800AW or FAV9800AW failing with error codes dc or UC or both to the Console display? If you are I believe you are experiencing a clutch malfunction with your machine. Take a look at this post and see if your problem is similar.
If you have error codes to the display when the machine fails in the last 11 minutes (I believe start od spin cycle) can you let us know what those error codes are?
please post the model and brand and ill see what i can do
