Tablets & eReaders Logo
Posted on Feb 06, 2011
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
How do u master clear a a pad tablet - Tablets & eReaders
Anonymous
Level 2:
Scholar:
  • Expert 59 Answers
  • Posted on Mar 10, 2011
Anonymous
Expert
Level 2:
Scholar:
Answers
59
Questions
0
Helped
36226
Points
120
If you mean an iPad by "a pad tablet", then completely clearing it is very simple:
  1. Open up Preferences
  2. Select 'General'
  3. Select 'Reset'
  4. Tap 'Erase all content and Settings
This will completely wipe the iPad, returning it to it's factory state.
Hope that helps!
2answers
Want to clear out all my stuff to give my LG tablet away how do i do that
The model number LGV498, the LG G Pad II 8.0 design is similar to its predecessor. However, the tablet is seen featuring full-size USB port, which can be used to connect with portable drives, keyboards, and gaming controllers, apart from being used to charge other devices as well.
This tablet comes with a slimmer capacitive stylus with 3.5mm width. Besides a support for an external storage via microSD card (up to 128GB), the LG G Pad II 8.0 houses the company's own LG-QPair 2.0 app, Microsoft Office apps and Quick Memo+ feature among others. The KnockON feature is also included.
As for the specifications, the Android 5.0 Lollipop-based LG G Pad II 8.0 tablet equips an 8-inch WXGA (1280x800 pixels) resolution IPS display like the first-gen G Pad 8.0, and is powered by a 1.2GHz quad-core Qualcomm Snapdragon 400 processor, clubbed with 1.5GB RAM, which is a slight bump from the previous generation's 1GB.
The LG G Pad II 8.0 includes an inbuilt 32GB of eMMC storage, along with Bluetooth 4.0, GPS and Wi-Fi connectivity options. Measuring 210.8x124.2x8.95mm, the tablet weighs 347 grams and is backed by the same 4200mAh battery for 10 hours+ of use. Hope this honest review help in your decision to this amazing LG tablet Amazon com LG Pad 8 0 16GB 2nd Gen GSM Unlocked by AT Wi Fi Android Tablet...
IT TELLS ME THERE IS NOT ENOUGH SPACE TO ADD GAMES AND NOT THAT MANY ON IT
1) download an app called Clear Master
2) Clear all Junk and make space
3 Move to the ext memory the apps that are space intensive
Enjoy
How do I turn on the bluetooth on my Z T PAD
You must turn on the tablet's Bluetooth radio before you can enjoy using any Bluetoothy peripherals. Here's how to activate Bluetooth on an Android tablet:
  1. Open the Settings app.
  2. On some Samsung tablets, touch the Connections tab.
  3. Ensure that the master control next to the Bluetooth item is set to On.
    Slide the icon to the right to activate.
    When Bluetooth is on, the Bluetooth status icon appears. It uses the Bluetooth logo.
To turn off Bluetooth, repeat these steps, but slide the master control to the left, to the Off position.
You'll also find a Bluetooth switch in the tablet's Quick Actions.
I uninstalled facebook on my tablet n tried to reinstal it n it says it is still installed what do I do
get clean master and clean all traces of that app see link bellow. you will clear all the facebook app data and be able to re-install it again
Free Download APK File of the Clean Master v5 8 8 for Android APK4Fun .
I want to clean my eepad prior or giving to my granddaughter
The way to Hard Reset ASUS Eee Pad Transformer TF101-A1 to Full Factory Reset: For those who have any troubles with your ASUS Eee Pad Transformer, use the 10-12 sec force power off trick to attempt a fix. If that doesn't help, backup whatever you want to keep and perform a full factory reset.
Some times you will discover error when asus transformer hard reset, like not responding to your device or your gadget not responsible. Don't be worry, simply just restart this and wait a minute. I think's it's side-effects of hard reset ASUS Eee Pad Transformer TF101-A1.
My ASUS will turn on and show screen with ASUS logo but will not go to home screen it just stays loading
FINALLY RESET REQUIRED FOR THE TABLET, JUST PUSH THE RESET BUTTON ADAJACENT TO THE VOLUME BUTTON, WHICH WILL LOOK LIKE A PIN HOLE. INSERT AN JUMP CLIP FIRMLY BY STRAINGING IT AND WAIT FOR 10 - 15 SECONDS TO MASTER RESET. THEN ENJOY....
1helpful
Cannot install candy crush on asus memo pad hd 7. I get unknown error code "-24".
You will need to do a factory reset on the device. This should clear up this issue & then you should be able to download the Candy Crush application again afterwards.
My Asus memo pad 7 will not download paid apps
Have you tried doing a factory reset? Try doing this under the settings menu, which should clear up any issues & then you can try to download your desired apps again.
Top Tablets & eReaders Experts
k24674
ADMIN Andrew
ADMIN Andrew
Are you a Tablet and eReader Expert? Answer questions, earn points and help others
