Question about Whirlpool Cabrio WTW6600SBT Top Load Washer
My Whirlpool Cabrio washer won't start when pushing the start button...I do have power to the washer.
  • Steven Hill
    Steven Hill Apr 15, 2015
    I had the same problem. Come to find out, there is a small piece of plastic on the control board that makes physical contact with the switch. This little piece was broken off. I disassembled the board and super glued the plastic piece back on which worked until I could replace the board.
    President:
  • 1,554 Answers
The Start button is broken, the user interface board is not working, or the machine/motor control board is out. Perform the diagnostic test to verify all machine functions. The Start button is indeed broken if machine functions work fine during the diagnostic test.
Put the machine in standby mode by plugging it in with all indicators off, or with only the Clothes Clean or Done indicator on. Select any one button except POWER, START, and STOP then follow the steps below, using the same button.
Press/hold for 3 seconds, release for 3 seconds, press/hold for 3 seconds, release for 3 seconds then press/hold for 3 seconds and release. All indicators on the console will be lit for 5 seconds with 88 showing in the Estimated Time Remaining two-digit display to indicate that the diagnostic mode has been entered successfully. If indicators do not display as described, the press/hold and release procedure may not have been performed within the time frame necessary for successful entry. Repeat the procedure and you may use another button to ensure this was not the cause.
The program then checks for saved fault codes. Post back any saved fault code for further advice. If there are no saved fault codes, all indicators on the console will momentarily turn off, then turn back on with 88 displayed and after 5 seconds, the diagnostic test begins with C0 displayed and the lid may be opened. Press the same button used in activating the diagnostic test above to advance through automatic test steps. Allow step C1 to complete before advancing to the next steps. Post back the result fro further troubleshooting advice.
Posted on Feb 07, 2011
  • Jahn27
    Jahn27 Feb 07, 2011
    Run the console and indicators diagnostic test if machine functions work fine during the diagnostic test. From Standby (Off) Mode press and release (key-dance) the following buttons within 4 seconds:
    The two-digit display will show dt if the activation is successful then within 5 seconds press START and all indicators in display will be lit with 88 is displayed. Press START a second time and this turns off the status indicators and the two-digit display with all other indicators remain lit. Press START a third time and this turns on the status indicators and the two-digit display with all indicators are lit.
    Rotate the WASH CYCLE selector knob back and forth and all indicators will toggle on or off. Press the buttons to verify function. and the corespondent indicator will toggle on or off and a beep tone will sound. Pressing SOIL LEVEL, SPIN SPEED, WATER LEVEL or LOAD SIZE, and WASH/RINSE TEMP will cause all indicators above these buttons to toggle on or off at one time. Press the STOP or POWER button at any time to exit diagnostic test modes.
    Let
    us know if you need further advice. Please accept
    the solution should you find it helpful and informative. Accepting the
    solution will not stop you from communicating with the expert. You can
    still communicate with the expert as long as you need further advice
    regarding the issue stated herein.
  • Nancy Reiser May 18, 2013
    we did diagnostic test and when it hit C8 it only did a slow agitation and would not drain and spin
    New Friend:
Hello, I had the same problem. I installed a new drain pump, and it's back up and running. The pump was $60 on Ebay, I bought it a few months before, because my old one had a small leak in it which I repaired, and I thought I could get a few more months out of it before I installed the new one. I guess it finally stopped working, and thankfully I had the new on ready to go. Really easy installation if you are or you know a handyman. 3 screws, disconnect 2 hose clamps and unplug the power connector on the pump. Easy.
Posted on Apr 29, 2014
  • Allen Clarke
    Allen Clarke Apr 29, 2014
  • janet
    janet Jun 30, 2014
    The key/dance does not work on mine. I tried holding the start button for 5 seconds to reset the lid lock and after 3 seconds, the 88 and all lights lit up. The only light not lit was the lid lock. I have not been able to reset it. I'm now searching for how to disable the lid lock so I can wash clothes.
3 Suggested Answers
tzweeb
Tom Zwiebel
  • 318 Answers
SOURCE: push start button on control panel - machine does not start
only 2 things can cause this.
1 the control is set to lock out mode. just hold the lock button for 5 seconds and it should go back to normal mode.
or 2 the controls user interface has an internal failure. its the part that has the switches and tells the computer what to do. either way call whirlpool and see if its still covered by their warranty.
of yeah and the 3rd thing is you have no power to unit. make sure the outlet is good by trying something else in the same outlet, like a light or hairdryer.
Posted on Jan 06, 2009
Anonymous
  • 82 Answers
SOURCE: Cabrio washer want start.
leave the door open and try it again if it does the same thing as before the door lock has gone
Posted on Jun 27, 2009
mc1bean
Mike Cairns
  • 3053 Answers
SOURCE: my whirlpool cabrio washer turns on but won"t
Hello, strong
I am trying to help you out here. Maybe this will help some? I am know on Fixya as the cleanup expert pro. Which means I spend my own personal time to seek out customers that maybe have not had there problem yet solved by the other fantastic great experts. I do this on my own for free. Think of me as a Specialized Trouble Shooter.
I have found out that it appears that lots of customers appreciate my efforts and help. So, I thought I would take some of my own personal time
to see if I can help you. Even though this Informational site may not have your exact model or brand, But this site will help you a lot. Here is the site link about everything you want to know about washing machines and possibly yours, from repair to trouble shooting it.
http://home.howstuffworks.com/how-to-repair-a-washing-machine.htm
Please if this helped you at all, if you can find the time and in your heart to rate my help and some kind words written would be appreciated for my free help, I would appreciate it. Like I said I just try to help, If anything this is good information for future problems. If you felt that my free help was a waist of time for you, I'm sorry. I do not get paid to help people on the site, I do it cause I like to help and maybe make a smile on someones face.
Here is also my direct link to my own pages of other areas of my expertise for other problems you might have in Automotive, Appliance, and Electronics. Drop In anytime for my help.
http://beta.fixya.com/users/mc1bean
Thanks Mike
Posted on Nov 01, 2011
My whirlpool cabrio washer #wtw555oxwo won't work. The lid lock light keeps flashing and the washer won't start
Possible that the switch is defective, there is fault in the line to the control unit from the switch of the control unit is faulty.
check these one by one.
Sep 03, 2012 | Whirlpool WTW5550XW Energy Star Qualified...
Jun 27, 2009 | Whirlpool Cabrio WTW6600SBT Top Load...
It takes a long time for my whirpool cabrio washer to start...
not likely. first thing is to unplug the unit for a few minutes. then plug it back in and try to run any cycle again.
if the buttons are hard to push, then you may have a "user interface" needing replaced. if it won start on any cycle, then it might be a control board.
i would check to see how old this is as it might be under warranty.
if its not covered, then call whirlpool and ask if they can help you with the cost of the repairs.
you would be surprised to find out that they do give concessions on alot of these to keep people happy.
Mar 31, 2009 | Whirlpool Cabrio WTW6600SBT Top Load...
Whirlpool Cabrio WTW6600SBT Top Load Washer Logo
18,442 people viewed this question
Marvin
Marvin
Gerry Harvey
Gerry Harvey
