Power cycling can solve a lot of odd problems with Vizio TVs. First disconnect the TV's power cord from the power outlet and leave it unplugged. Then press and hold the power button on the TV for 10 seconds. After you have held the button for 10 seconds, let go then try to power the TV on.
This happened to me yesterday. My daughter put a penny and a dime in the SD slot and none of the buttons or volume were working on my TV.Only the power button would work.
I fixed it by simply removing the penny and dime out of the SD slot and then i held the power button for 10 seconds. After I unplugged the TV from its power source for 5 minutes and then plug it back in. When I turned the TV back on everything was back to normal.
For a second I thought I was going to have to buy a new TV, lol. Hope this helps. If it doesn't work the first time then try it a second time.
By the way I have a Panasonic PT-52LCX66 LCD Projection TV..
First, unplug power cable from the back of your TV. You will notice the flashing light is still flashing. Don't worry, go to the Second step.
Second, keep pressing on the POWER button, located on the panel at the top of your TV, to shut off your TV. This will stop the flashing light from appearing.
Third, Plug the power cable back onto your TV
Fourth, press the POWER botton ONCE, using the same button used in the Second step to turn your TV back on.
Fifth, you will see the POWER light comes on, as normal.
Sixth, using your remote control, press the green button to turn on. Your TV should work as normal.
