Question about Sony KLV32S400A 32 in. LCD TV
Hi Am working on a sony lcd tv model no. KLV- 19T400A. The problem is that when I switch it on It tries to power but Enters into self diagnosis with the red LED blinking 5 times.
    Top Expert:
  • Sony Master
  • 30,692 Answers
That is a video fault.
Five blinks
- AKB circuit (automatic kine bias), the timer/standby indicator blinks for about 30 seconds then goes to the self-diagnosis function. Something is wrong with the video.
Posted on May 18, 2018
4 Suggested Answers
6ya staff
SOURCE:
specialistel
  • 8909 Answers
SOURCE: I have sony Bravia KLV
AKB circuit (automatic kine bias), the timer/standby indicator blinks for about 30 seconds then goes to the self-diagnosis function. Something is wrong with the video. Check video out, Q705, 732, 761 and other components on the C board, also check Q218, 219, 220 on the A board. In addition, unit could be in IK blanking, try turning up screen slightly.
Posted on Mar 09, 2011
Ecollier2012
Edward
  • 3459 Answers
SOURCE: Sony LCD TV Model #KLV-23HR2 The timer LED
This is a common problem an a failry easy DIY fix.
Plasma and LCD TV sets are prone to having capacitors in the power supply section fail. This is the most likely cause for the probem you describe. When capacitors fail your will commonly see one or more of the following symptoms.
  • No video, Power light is on or blinking.
  • TV is making a clicking noise.
  • TV takes a while to come on
  • Screen is very dim or flickers.
Again, You can get a power supply repair kit with the parts, detailed instructions, and support from sites such as www.TvRepairKits.com . Or just click here to see more details on their kit.
Here are pictures of capacitors...Notice that the ones below look bloated. They have failed and will need to be repalced.
Capacitor being replaced! Fairly easy DIY fix.
Posted on May 01, 2011
jdvillanueva
Jdvillanueva
  • 2098 Answers
SOURCE: My klv-s40a10 tv turns on
Hi sandersonkie,
Sad to say because 4 flashes of the led light at the front panel is an error code for faulty "LCD Panel". This is the expensive parts on the unit, almost same cost of a new set if you are going to send it in for parts and labor. Check if your unit is still under warranty/extended warranty period, avail it because the manufacturer will fix it for free. If not, new unit is more practical than to send it in.
Hope I helped you.
Have a nice day!
Thanks for using Fixya.
Posted on Jul 28, 2011
How can i fix str for sony tv/klv-19t400a?
The main power supply regulator section circuit fault. Either it will be a separate board, or the part of main board. Check and replace damaged component/s at its main power regulator [SMPS] section circuit. Contact any service technician. If you wish to get some details; check the site linked here. Pull up older posts. http://electronicshelponline.blogspot.com/ It will be best to replace the power supply regulator board as card basis rather than making "Surgery" to it; which usually will make loss for both money and time. Even though you can make it right, it will cost around an amount equal to the cost of a new board; including the cost of (spare parts + service charge) More to say, most of the spare parts to it will be difficult to get from open electronic spare part market. This is true to most of the flat panel TV power supply boards; irrespective of its brand and screen size.
Search the site by type in the "brand name" to your device; in the "Search box at the top right of the display window of the Homepage" to get gathered related posts.
Oct 18, 2016 | Sony KLV-19T400A 19 inch Multi-System LCD...
Sony Bravia KLV-40S200A LCD TV standby indicator blinks 5 times
Here is a link to the service manual--
http://www.scribd.com/doc/46056922/KLV-23S200A-and-Other
Page 11 explains the error codes--unless you are a tech with a meter etc it will be a shop repair.
A lot of good info including taking set apart correctly.
"abnormal power"
SD TECH
Jun 02, 2012 | Sony BRAVIA KDL-40S2010 40 in. LCD...
Buy KLV-32U300A power supply
Hi.
This model was distributed only in few countries. Replacement parts are not available from third party distributors.
Please contact Sony at the number listed on the owners manual or check your local Sony website for the support contact.
Sony Global
Sony eSupport - Electronics
KLV-32U300A - Sony South Africa
Nov 29, 2011 | Sony Bravia KLV-32U300A 32 in. HD-Ready...
Model no. klv-22bx300 problem- green light
my sony KLV-22BX300 Tv when turn power on green led blinking,
and menu function not working properly
Jul 19, 2010 | Sony KDF-E50A10 50 in. LCD HDTV
We have a Sony Bravia lcd tv model KLV-S40A10 - no power
Hi,the problem is from the fuse in the tv,it's blown and it's a means of in-built security against power fluctuations from damaging the unit,so the solution is to replace the fuse of the TV to restore your unit back to a normal working condition.
Be cool.
Jun 13, 2010 | Televison & Video
Sony KLV-32M1 LCD TV switches off/on
in this situation autoshutt off in few seconds no sounds and pictures. you have to check the secondary power supply. check all capacitors. budged capacitors can make shutt off sytem. capacitors blown on top due to hot pressure inside tv.
Jul 08, 2009 | Televison & Video
REPLACEMENT LCD PANEL
Have a look here I have the same problem and have been looking for 3 days...I hope this helps as I have tried the service manual and the part number is...1-805-870-21...with no luck...http://www.invertercentral.com/qrySpecSheet.asp?page=srlp&name=LTA320W2-L02&number=LTA320W2-L02&title=Toshiba&Country=Australia
Nov 21, 2007 | Sony KLV-S32A10 32 in. HD-Ready LCD...
Sony KLV32S400A 32 in. LCD TV Logo
176 people viewed this question
Top Sony Televison & Video Experts
Jerry Greenberg
Jerry Greenberg
Ekse
Are you a Sony Televison and Video Expert? Answer questions, earn points and help others
