I turned on the tv on the set itself. It went on very briefly and then turned off. The red light blinks several times and then stops blinking. After a very short time it will blink again for the same amount of times.
When I push the power button nothing happens: no click and it does not turn on.
the only way is by bringing to a tech.i think there is no need fro self-fixing with problems like this.try tapping the tv several times then turn it on.
Use your warranty in a hurry before it expires. Your TV when into protection mode to prevent further damage. Most TVs have a 1 year warranty. Good Luck.
If the front power light is blinking three times then your TV has a problem with the convergence. You can get the correct replacement parts and full step by step photo instructions from www.TvRepairKits.com
i hve the same problem. I turned on my Sharp Aquos lc-32d62u HDTV last night for the first time, but it is black and a blinking green light.
did you find a solution?
You need to change the seven capacitors on the DM power supply board (inside the metal case on the left where your DTV tuner connects)They are 1000 MFD 16 VOLT capacitors and the tops are probably bulging outward because they are leaky- this is a common problem.When you lost power,the TV had to reboot itself but because of the leaky caps it never will and the green light keeps blinking.As long as you never lost power or unplugged the set the TV would of still worked.Once you change the parts and plug the set in the light will blink normaly for about a minute and when it stops blinking you can then turn on the TV.
