SOURCE: screen is sideways
this is ok, either someone's yanking your chain, or you accidently activated an ability of your graphics chip, this mode is for "tablet" PCs which have a portrait mode. you most likely have an icon in the bottom left of your screen by the clock for graphics settings, one of these will be to rotate the screen.
it is also possible that this ability may be programmed to one of the hotkeys, however without model info I cannot tell.
your mouse should have flipped too, if not then someone may be fooling with you..
check if you can click your icons... if you cannot then right click on the desktop and change the wallpaper on your desktop, also re-enable your icons from this menu, you may also need to unhide your start bar
hope this helps
SOURCE: i have some how managed to turn the srceen view sideways
Ctrl+alt+up
Please rate this solution.
