You have given me no info reguarding the error so i am posting you entire guide through which you may diagnoge the error and we may work on it. Believe this troubleshooting guide should help
Is this actually preventing you from shooting? Normally, the r-number shows up when you press the shutter release button to show the number of shots you can take in the current burst before the buffer fills up. It shouldn't keep you from shooting.
It might be helpful if you provide the full model number of the Siemens dishwasher. Most likely E14 error has something to do with water flow sensing. Check if your mains water pressure is ok (tap under sink is fully open). But can provide more details only if you can tell me the model number.
what website are you trying to get to? is there an "https" before the www? try removing it...or adding it if it's not there. can you give more info on what the error says? is there an error number?
If this camera just show blue screen it means that the LCD or he mainboard of the camera is defective., is this error code display also a number., usually it will also display the error code number.
If you have this error code please call tech support toll free 1 800 235 6325 and send the camera for repair
Error showing 113 - Had pro check it out, all systems normal (voltages, gas, etc.). Spent $310 and ordered new control assembly from Amazon (pool store wanted $425) installed myself in under 2mins and heater works perfectly again.
Zodiac R0366200 Heater Control Assembly Replacement for Zodiac Jandy Lite2LJ Pool and Spa Heater
I had this error. There was an old rule for an old device that was no loonger connected. If a device that has a rule is not connected, no information will show up telling you there is a rule. But it already exists and is hidden. The rule will only show up when the device is connected. But the rule is active wether or not the device is connected.
The only .I found to fix this is to reset the router to defualt settings, this will remove the old device and it's tules from memotry.
Go to Setting-Network-Operator Selection. Keep it Automatic
Go to Setting-Call-Send my caller ID. Keep it Set by network
& check your line in use. Keep it in Line 1
