Have you got the right model number this is an LCD TV, not a back projection set which uses a projection system. There is no bulb to take out on this model number.
I do have the right model # Sony Bravia KDL-40W3000 according to my receipt and book.
The tv came on and immediately went off and that red light blinked for 13 times.
What else can you suggest is wrong because this is the answer I find everywhere, that the lamp needs to be replaced. Thanks
I have just downloaded and read the manual.
This is NOT a back projection TV, it is a standard LCD tv.
The error code you are getting means it needs to be serviced but there is no user serviceable lamp.
There is a backlight for the LCD but that is not a user serviceable item and would be difficult and expensive to repair.
The 13 blinks means the inverter board has failed, this powers the back light for the LCD screen.
You will need to get it serviced by sony engineer.
Thanks so much for the help. I finally realized I have to say LCD tv along with the model #. I will have to take it in for repair. Thanks for your help.
