Samsung LNT5265F 52 in. LCD HDTV Logo
Posted on May 19, 2017
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
My TV, Samsung LN-T5265F has 4 inverter boards. I do not see any capacitors on any of the 4 boards. I tried sniffing each of the boards and think, by smell, the upper left board is bad, but I am not positive. How can I test each board to determine which is the bad unit. I do not want to replace each one. The symptoms of this problem is no picture, but if I shine a bright light on the screen front I can read most of the menu. I looked at all capacitors on the power supply board and they all look fine.
Level 3:
Top Expert:
  • Samsung Master 76,851 Answers
  • Posted on May 19, 2017
Samsung Master
Level 3:
Top Expert:
Answers
76851
Questions
30
Helped
15007063
Points
237762
We can't detect a faulty board by smell, like dogs do. You should check its circuit. If you wish to get some details; visit the site linked here. Pull up older posts.
5 Related Answers
Jaime Hernandez
  • 2351 Answers
  • Posted on Jan 05, 2009
SOURCE: Samsung LN-S4051d power supply board
The replacement of the power supply is quite easy. You will have to remove the base if applicable and the back cover, once you remove it; you should see the power supply.
Click here to see how the power supply looks like and availability or Click here to find a cheaper one.
I can also repair your power supply. If you need further assistance you can write to [email protected]
Anonymous
  • 133 Answers
  • Posted on Jan 10, 2009
SOURCE: Screen goes completely out.
when it blanks out, tuen the lights out in the room, and shine a flash light at the screen, see if you can see the picture, if you can, it is the inverter moard blamking out, thats the board that lights the back lights, if you cant, hit the input button on the remote, if the TV comes back with a picture, it is a problem with the main board, in paticular the componant input on the main board
Anonymous
  • Posted on Mar 13, 2009
SOURCE: Samsung LN-T5265F
Samsung LN-T5265F S POWER SUPPLY UNIT BN44-00150A
Anonymous
  • 227 Answers
  • Posted on Jun 21, 2009
SOURCE: Samsung LN-T5265F Clicks constantly but wont come on
that's the power supply circuit, you have to replace some bad capacitor, you will a technician to fix this problem, you are looking at $250.00 for this repair
if you are in MD call 443-449-4559. good luck
smbaby
  • Posted on Sep 22, 2009
SOURCE: Samsung LN-R408D - No Picture
My Mom's LNR408D also had sound but no picture. I was able to fix it by soldering in a jumper wire across a blown (1.5A ???) SMD picofuse on the "T-Con" board.
Consider attempting this ONLY if you: 0) Know enough to avoid the potentially fatal High Voltage parts of the power supply board!!!
1) Are a fearless hackazoid 2) know what you're doing with a soldering iron and teensie SMD parts 3) are gonna throw the busted thing out anyway so you have nothing to lose and won't be sad if you screw something up.
4) Know enough to avoid the potentially FATAL High Voltage parts of the power supply board!!!!!
This board is at the top center under a close fitting RF shield. The suspect part was labeled "CP" on the board and marked with "P" on the part. It is visible above the right-center of the connector from the main board. An ohmmeter showed it as open, so I bypassed it with a jumper wire from connector VIN to the hot side of C13. One image shows the suspect part and the jumper in place.
The other shows the TCON board placement top-center (under its RF shield). With care, it seems possible to test the fuse and put the jumper in place without removing the shield. (Obviously don't touch anything else with the VOM leads!)
Thanks to ZORBUS and Steve's TV and Electronics for the idea.
http://www.avforums.com/forums/lcd-televisions/892447-no-picture-but-got-sound-my-samsung-lcd.html
http://www.gesda.com/transformer/Fall08_files/Page336.htm
Steve C
3helpful
Very dark picture on LN-T5265F. Can hardly tell the set is on without shinning a light on front. If I was not careful when looking at the set I would state there is no picture at all, but that would be...
The problem is in the inverter. Replace all the capacitors in the inverter and you'll get it back to work. The inverter is a module inside wich is responsable with the display backlight. You can buy whole module (inverter) from the internet. Before that you should know: the working voltage (can be measured on the central big capacitor pins located near the connector plug); The number of lamps (see how many pink wires get out to the back of the display). Usualy the LCD tv's have inside two boards. One is the logic board and the other is the inverter. Sometimes these two modules are on the same board. If they are separated, they are conected togheter with 4 main wires: ON (power on command), DIM (dimmer command), NEG (negative), POS (positive wire).
I have a Samsung LCD TV Model# LN-T5265F ..its less than 3yrs old...when i turn it on it keeps on clicking and never turns on...what could the problem be ... Thank you, Jacky
View the utube video to repair the tv. Mine did that, and I fixed the capacitors on the power supply. They're available on Ebay for five bucks. Don't be intimidated, it's not hard.
2answers
My samsung tv model # LN-T4665F turns on and I hear audio but see no video. You cannot see the menu prompts when menu button is pushed. Nothing. This has happened in the past and usually after 24 to 48...
Ur tv the 2 long boards call the LCD inverter board it starting to have problems,that why this is happening.Just not any components on the board are dead yet that all.The LCD inverter board,that the board that help the tv to have a backlight to the LCD screen to produce a picture.When this problems happen for good,change the 2 long LCD inverter boards will solved this problems.
2answers
LN-T5265F Samsung takes couple min to power on (clicking while).
Take the back off and look at the power supply. Top right on the board, see if a capacitor has gone bad. I've seen up to 4 caps go bad in the little area. replace with a higher voltage and you'll be good to go.
2helpful
2answers
Samsung 32 lcd tv backlight off after 4 sec. audio ok
If your TV is staying on and you hear audio after the picture goes dark, then you have a problem with a CCFL or the inverter circuitry that drives them.
Most likely an inverter problem.
Like a bad xformer (usually fogged up plastic wrapper)
Or a bad cap (bulged, swollen, cracked)
Or maybe a shorted IC or transistor (test for short circuit between the different pins of the device)
2helpful
2answers
Samsung LN-T5265F
Grand Canyon Tech
Grand Canyon Tech
 Grubhead
Grubhead
