SOURCE: i need part no for engine assy. Kawasaki Mule
back fire through carb when you let off gas have to run with choke on
SOURCE: kawasaki mule heat light staying on
Replace the impeller in your water pump. It's an easy job and needs to be done every 2 or 3 years depending on use. Why they put a rubber impeller in these I do not know. Your local Kawasaki dealer will be able to help you with the part.
SOURCE: I have a Kawasaki Mule 3000. It is hard to keep
take the spring off the screw and use teflon tape so you can adjust the screw further
