Dryers Logo
Posted on Feb 08, 2011
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
I have a kenmore electric dryer model # 110.64632301 and when you push the start button it won't come on I've cleaned it out unplugged and replugged, flipped the breaker, and when it is plugged in the light on the inside comes on.
Bruce Denton
Level 2:
Sergeant:
  • Expert 273 Answers
  • Posted on Feb 08, 2011
Bruce Denton
Expert
Level 2:
Sergeant:
Answers
273
Questions
Helped
51221
Points
772
The dryer door switch could be bad..its also possible the thermal fuse is bad. its behind the rear cover. the first thing to do ..is unplug the dryer. the thermal looks like a white bullit shaped object with two wires on it..they have one screw that holds it on. its located above the thermostats on left side. touch the two wires together. be careful not to let them come in contact with the cabinet..insulate them with electrical tape. if it comes on..you can use it, but get that part replaced the next day
It will not turn on. When I unplug it and plug it back in the start light is constantly blinking. I checked for error codes and the 4 lights blink 9 times and the start button blinks 14 times.
Electric dryer no start does nothing
Check dryer Terminal block prongs both outside prongs should give combined 220, and 110 each if u check 1 outside & 1 center (ground) prong. Also check house electrical outlet for full voltage.
CHECK THERMAL SHUT OFF THERMOSTAT USUALLY LOCATED ON THE BLOWER. for OHMS or resistance with a meter. Should show a closed circuit. Ohms WHEN THIS FUSE BLOWS IT WILL SHUT DOWN EVERYTHING.
NEXT Test the PUSH start switch with meter for OHMS. Should show OHMS when pushed in or on start, and no ohms or infinity when in off position.
If you hear a humming/clicking sound from motor area you more than likely have a bad motor.
Try this test out to see if u have weak windings or relay/capacitor on motor.
Open the dryer door and turn by hand the drum while machine is on ON position. And you or someone else presses the door engagement switch in. If it starts up then u have bad windings
Another thing to check is the belt safety switch. With a multi meter.
Especially if u just replaced the belt. The belt safety switch is attached to the Tensioner and motor. IT LOOKS LIKE A DOOR SWITCH SOMEWHAT a little black pc of plastic with 2 prongs going into it. Sits at bottom of motor. Under the Tensioner. Attach meter clips to the 2 prongs on switch, Then when the little white push button is pressed in it should show continuity and none when released.
Lastly check ur DOOR SWITCH for continuity with a meter when the button is pushed in the (on/Door closed position,) it may have gone bad.
https://www.youtube.com/watch?v=MhVUEhngZMg
https://www.youtube.com/watch?v=9xD7lCXJ0ZM
https://www.youtube.com/watch?v=sTRP6kHqAFs
Hey GOD IS GOOD !!!! WHICH IS WHY MY ADVICE IS FREE
Kenmore Whirlpool Dryer Won Start Easy Fix What to Test When Whirlpool or Kenmore Dryer Won Start or Run Kenmore Whirlpool Dryer Won Start Easy Fix Troubleshooting Why Your Dryer Won Start PartSelect com
2answers
Control Panel turns off
HI,
The PCB unit ie the control panel circuit board has gone bad. The probable cause of the same is moisture on the board.
Thanks
proton
Kenmore dryer model 110.74994300 push start does not stay on
Remove front panel
I have this same problem. The Sears Service Technician just left and said that my main panel needs replaced to a cost of $532.88! Needless to say I will be buying another dryer and it will not be a Kenmore....
The dryer has power but when I press start it won't do anything. I've unplugged it and replugged it. I've cleaned the lint out.
There can be many reasons why your dryer will not start or turn...
The most common causes are the belt breaking or jumping off, or the motor goingbad...
Here are a couple of tips that I wrote will help you to figure out why yourdryer will not run...
Dryer Repair - The Dryer is not Turning
Dryer Repair - The dryer will not start
heatman101
Jul 11, 2011 • LG Dryers
I have a kenmore he5 electric dryer. We have
I am having the same problem. I think there is a design problem. They have tried to fix mine 3 times (replacing the dryer with a new one on the first try!) My dryer is only years old. I'm so disappointed with Sears and Kenmore.
1helpful
2answers
Th pilot won't start ,motor start but won't light the pilot
I have a Kenmore Series 80 (Model # 66812694, Stock # 66812) that will not start. The light comes on, but no power when you push the start button. I have checked the fuse box and everything is fine. I've also tried unplugging for 10-15 minutes and replugging it in, but no success. Any suggestions?
Kenmore Dryer stop running when release the start button
I have whirlpool dryer, when i push the start button it will start but only stay on for part of the drying time. no the start button make noise when push and after keep trying it stop.
1helpful
Kenmore Dryer 80 series will not turn on.
HI thanks for your question. theres a belt break switch on the dryer so that if the belt breaks it wont allow the dryer to start. check that. thanks the appliance doc. please rate my answer .thanks
Top Dryers Experts
john h
