Yamaha DTXplorer 5 Electronic Drum Set Logo
Posted on Feb 09, 2011
My dtxplore has a flashing screen and wont work
My zoom g1x is not working even in battery...the screen always flashing "tr" and it is stuck on it
If you need to trouble shoot it you may download the service manual for free from
Elektrotanya com
May 24, 2018 • Zoom Music
D888 recorder/mixer wont boot up. Screen says "power on failure" initialize" appears that hard drive has failed. though I hear it running
The hard drive has probably failed. In spite of it rotating, the head servo and electronics has to work. I would recommend testing the drive in a computer to see if it works. You will likely have to reformat it after if it does work. FIRST look for obvious things in the D888 like cable that is partially off or loose.
Compact flash that i bought wont work san disk 4 g ultra says error 9
USUALLY the ultra and high density flash cards have trouble working in most music equipment.
Only buy the cards up to 2 Gb and verify compatibility with one of them before buying more.
My roland discover 5 wont tune - not to default 440Hz or any others - wont stabilize - and the bottom corner of touchscreen where it says"440 -Do it" for resseting to default concert pitch dowant work/...
The unit may have the problem that befalls the Palm Pilots where something gets under the escutcheon and presses on the touch screen at the edge which overrides any other inputs.
Another possibility is a stuck button. The buttons are usually scanned as a matrix and at startup if a button is stuck that can make unit unresponsive.
Without a logic analyzer and the firmware listing you likely would not get far if one of the logic chips has gone bad unless it can be found using freeze mist and heat gun..
Stuck buttons or touch screen is usually easily found without schematic.
Faulty effects behringer djx700
The effects on the PMP powered mixers flash UNTIL you push in on the selector knob. This way you can dial in the next effect number and then push in later to activate when you want it... Could yours possibly be the same technique?
Top Yamaha Music Experts
Paul Bade
Are you a Yamaha Music Expert? Answer questions, earn points and help others
