Question about Panasonic Lumix DMC-ZR1 / DMC-ZX1 Digital Camera
My panasonic Lumix DMC-ZX1 shows 3 dark spots and 2 hairs on all pictures. When I zoom-in the dirt is more visible and when I zoom-uit I dont see the hairs any more and the dark spots appear wider and softer. Is this dirt on my lens or in de CCD sensor. What can I do to solve the problem?
Yes, you can clean. Not as complex as I originally thought.
1) Remove all of the silver screws
2) Separate the silver case (should split in 2)
3) Remove the 3 black screws in the middle
4) remove the center square cover that is over the lens
5) Use a duster spray to clean the lense and mirror
6) Reassemble in reverse order
Not knowing what I was going to get in, the entire process only took about 7-10 minutes.
Email me at malhokc1@yahoo.com with any questions.
Posted on Apr 03, 2011
  • 1 more comment
  • rpi9 Apr 04, 2011
    Thanks for your comment, but I did took the camera back to the store where I bought it. And although I didn't had warrantly left in the camera, I found out that the lense was covered for much longer. They admit that this is a common problem on this camera, en they took it in for repairs. So, my recommendation: always handy to check with your supplier before you start openning screws.
  • Tau1 Jul 12, 2011
    Hi
    I just followed KalMalhokokc1 's advice and though I went slowly it was a process just as described and no problem and I believe I solved the spot problem without having to loose my camera for a few weeks ( which I need for work ) So a huge thank you to Kalmalhokc1. Blue Skies
  • Malcolm Withell
    Malcolm Withell Apr 29, 2019
    My camera seems different inside. The three screws inside were on the rectangular back plate - there were none on the lens side that I could see - and after removing them, being very careful with the ribbon cables, I found there were still clips which I would have had to prise open. I didn't dare go any further. I've put everything back together, and it works, but the blob is still there (I didn't expect anything else but you can always hope!), and slightly darker if anything.
  • Panasonic Master
  • 6,771 Answers
I would clean the outer lens first, if that makes no difference the lens must be dis-assembled and cleaned in order to address this, the dirt is on the inside of the lens and any particles there must be removed, because what the lens see's will appear on your photo's.
Posted on Feb 09, 2011
  • rpi9 Feb 09, 2011
    I did already clean the outer lens and made no different. If the dirt is inside de lens (which can not officially be removed), could this problem be resolved within the garantie? The camera in question is quite new.
  • John Cunningham Feb 09, 2011
    If the camera is under warranty send it in, it should be covered, if dirt can get in that easy ,the lens construction must be questioned.
    New Friend:
I was told that it wasn't covered under warranty - hence mine still has dust inside the lens. I will try to do what Kalmalhokc1 has suggested - am getting some canned air next pay day - and see what I can do.
Posted on Jul 09, 2011
6ya staff
SOURCE:
I tried to edit an image on sd card in Panasonic DMC-ZX1 via PC. Now camera will not recognise any card and will record only to internal memory. Card works in PC. What are my options?
First, back up any important stuff to the PC. Then format the card in the camera.
In the future, avoid doing stuff on the card. Copy the image to the PC, edit it there, then copy it back to the card. Be aware that any edited photos may not be visible on the camera.
Nov 21, 2016 | Panasonic Lumix DMC-ZR1 / DMC-ZX1 Digital...
Where do I load 2 batteries in the digipower rapid charger
Panasonic DMW-BCG10, DMW-BCG10E, DMW-BCG10PP Battery, Technical Specification: Battery Type: Li-ion, Voltage: 3.60V, Capacity: 895mAh. Dimension: 41.60 x 30.40 x 9.40 mm, Product Type: Replacement Battery (Brand New). Compatible with: Panasonic Lumix DMC-TZ10 Series, Panasonic Lumix DMC-TZ18 Series, Panasonic Lumix DMC-TZ20 Series, Panasonic Lumix DMC-ZR1 Series, Panasonic Lumix DMC-ZR3 Series, Panasonic Lumix DMC-ZS1 Series , Panasonic Lumix DMC-ZS10 Series, Panasonic Lumix DMC-ZS3 Series, Panasonic Lumix DMC-ZS8 Series, Panasonic Lumix DMC-ZX1 Series, Panasonic Lumix DMC-ZX3 Series. Panasonic Lumix DMC-TZ22, Panasonic Lumix DMC-TZ6, DMC-TZ8 and Panasonic Lumix DMC-ZS5, DMC-ZS7.
Panasonic DMW-BCG10 Battery
Jun 04, 2012 | Digipower Battery Charger
Panasonic DMC-ZR1 has foreign object inside lens. Can I open camera and use compressed air to clear this out? Shows on zoom.
The practical answer is that you can't open the camera and use compressed air. The real answer is..."sure....open it up and grab that can of compressed air. Just don't be surprised or upset when you put the camera back together and it no longer works. But the experience will be fun." If the foreign object doesn't actually appear on the pictures, don't worry about it. All lenses have stuff and dust inside. It will move around as time passes.
Oct 06, 2011 | Panasonic Lumix DMC-ZR1 / DMC-ZX1 Digital...
Black marks found on image
sir u contact ur near service center this is simple problum just clean ur camera CCD
Mar 02, 2008 | Panasonic Lumix DMC-FX01 Digital Camera
Dark circle in middle of picture
I had the same problem too! When zoomed in, those spots become very visible. I try hitting it off but it's still there.. can anyone help us???
Feb 08, 2008 | Panasonic Lumix DMC-FX01 Digital Camera
RED DOT
If the dot is not visible in print, but only on the camera's screen, the its only the LCD that is faulty.
If the dot is visible on screens and in print, then yes, it could be the sensor. Try taking pictures without the digital zoom. Chances are the dot is only visible with the digital zoom because the picture is interpolated.
If all else fails, you can try cloning out the spot in an image editor on the computer.
Dec 01, 2007 | Panasonic Lumix DMC-FZ7 Digital Camera
Panasonic Lumix DMC-ZR1 / DMC-ZX1 Digital Camera Logo
2,632 people viewed this question
Top Panasonic Cameras Experts
Ekse
rajiv6089
Level 1 Expert
Are you a Panasonic Camera Expert? Answer questions, earn points and help others
