SOURCE: Samsung TV won't turn on- trying to fix it. A challenging problem
I had the same problem. I live in NJ and called the local authorized "service provide" listed on the Samsung website. What a joke. Quoted $350 just to show up, never showed up. So I opened my own TV. Took off the plastic back (10 screws) took off the large metal RF shield (12-14 screws) and noticed a blown component. The markings on the component were KL15L and it is apparently an NTC Thermistor. Obviously it got fried and not knowing if there was other damage I decided to set out to replace the entire Power PCB Board Assembly and not the component. There were two part numbers on the assembled board (BN97-00457E & BN94-00622E). After searching online I also found a suitable replacement number for these (BN96-04896A). I found two places who claimed to have the part or have it on order (shopjimmy.com and vancebaldwin.com). After placing orders with both and having neither come through, I broadened my search and found out that the LNR409D was basically the same model as my LNR408D so I looked for its Power PCB Board Assembly part number which turned out to be BN41-00521B. Google search for that part number showed the item available on ebay. I bought it a week ago (ebay 260311519904) for $144 plus $12 shipping. I removed the bad board an hour ago (6 screws about 7 connectors) installed the new one, plugged in the connectors, replaced the covers, plugged in the TV... AND IT WORKS!
Suggestion: If your TV is out of warranty then open it up (what have you got to lose) and see if the problem is obvious and maybe something you can fix (replace) yourself. The parts, spare boards, etc. are out there if you look.
SOURCE: Samsung LN-T4665F 46" HDTV Screen is BLACK - NO PICTURE
I am a Samsung certified Tech, they do have problems but when the LCD screen was replaced and the main board, they sould have replaced the FR board also
SOURCE: We have a samsung tv model no le40r88bd which have
eeprom needs replacing, i had same problem, changed mine myself only a few days ago, all seems ok.
SOURCE: We have Samsung LCD model LN26A450C1D, which is
The tv Tuner board is dead,that the board,where the brocasting incomming signal cable connected into it.Tries websites like Shopjimmy.com,Ebay.com to buy a refurbish Tuner board for the replacement.
Testimonial: "Thanks for quick response! I will try. "
