It could be a fuser, drum, developer, or transport belt problem among other things. The FS-C5016N is an old model color printer and if the maintenance kit has not been replaced it probably should be. THe maintenance kit contains the items above along with a few others.
Click on this link or copy and paste the complete link into your browser. If I could be of further assistance, let me know. If this helps or solves the issue, please rate it. Thanks, Joe
when you open the left cover you will see some green plastic things. If you pull these towards the left they will clean print heads and charge coronas. If this does not fix the problem the you will have to remove the dev and drum units from the machine. The print head sits on top of the drum unit and can be levered off with the three tabs gently lifted. the entire print head can be remove once the black cover has been unhitched from the sides. The print heads are not screwed in and what ever you do DO NOT TOUCH THE SCREWS on the print heads as they are only for density adjustment
