It has caused a screen bleed of the pixels. There is no way on repairing this unless you replace the whole screen which will cost as much as the t.v. itself. As time persist, the lines will become larger as the crack will spread.
If you wish to get some details; visit the site linked here. Pull up older posts. http://electronicshelponline.blogspot.com/
Line faults & possible causes to LCD & Plasma screen are given with illustrations. You can get an idea about the fault to an extent. Faults to all LCD & Plasma screen are similar, irrespective of its brand and screen size.
Search the site by type in the "BRAND NAME" of your device; (Exclude the model number), in the "Search box at the top right of the display window of the Homepage" to get gathered related posts
i have a 47" inch lcd sanyo t.v. and my kids accidentally shot it with an air-soft gun. and there is a crack where the pellet hit and there is also a crack running down that spot. Also the screen has these lines running up and down the screen. Different colors. and i was wondering if it was possible to fix.
Yes, thats correct. If lcd tv screen got hit by some thing then lcd panel got cracked and does show distorted lines or cracks instead of picture and lcd panel have to be replaced that would cost you 70% to 80% of new tv price. New TV is better option.
Thats a generic problem with LCD screens. Its more common in Mobile screens. Sorry, no there is no fix to it other than replacing the LCD itself. Just pray that it shall not grow because as and when the compressed gas from within the LCD will leak the line will be becoming broader and broader. It is caused by damage to the LCD corner Just a hit on side of LCD and a hairline crack for giving way to the encapsulated gas.
The possibility is that the heat generated by your plasma screen tv is affecting the outer mask of the screen causing the cracks to appear .
Or it may be that the screen has been struck in some fashion and the cracks are a result , do you have small children this is often a cause as they tend to hit things and you are unaware ?. My advice to you is to seek engineers assistance as soon as possible . regards Vortash
An lcd screen cannot be repaired, only replaced and for a cost around what the went for when new. You can try looking on ebay or craigslist for the same model and swap parts. Had it happen to me, it sucks. Also your home owners insurance should cover it. Sorry thats all the help I can be.
If you have not yet fixed this and haven't trashed the set I may have a solution.
I have a 50HP66 that has a good screen but bad sustain boards.
I will buy the boards from you...Easy to remove. Then you can use that money to buy a new TV.
Fixing a cracked screen is not practical. IE. Replacing the whole screen.
These sets are made to be sent to the land fill when the warranty is up.
Maybe we should have our lawmakers force companies to have minimum warranties for large toxic products that end up in the trash. Then they might make them last more than a year.
