Question about Hoover AAA160 Front Load Washer
I have a Hoover SE 160E which stops mid cycle with the start and crease guard lights flashing. The washing machine seems to stop prior to the rinse cycle and the drum has been emptied of most of the water.i can manually put it on drain and spin cycle. it stops soon after i put in on a rinse or wash cycle Any suggestions to the fault, could do with a quick fix as my 8 month old is fast running out of bibs fast? The appliance is over 5 years old.
5 Suggested Answers
6ya staff
SOURCE:
mikewheldon
SOURCE: Instructions for Hoover Washer Time 160E
i have a hoover soft wave maxi 1600 7.5kg AAA it spins and empty's and sometimes it don't what could be the fault
Posted on Dec 02, 2008
Anonymous
  • 105 Answers
SOURCE: what Temperature is crease guard. also fast wash
usually crease guard is a combination of hot and cold (warm depending on water temp and water pressures)
Hoover fast wash is generally a shorted time cycle of the normal washes
Posted on Nov 20, 2009
barkencoa
Barry Coates
  • 3463 Answers
SOURCE: Hoover hpe 236. water not draining, stops mid cycle, lights flash
Have you checked the pump filter, and or that the pump is actually working. if it spins o/k with no water in, then I would suspect a draining problem.
If filter clean and pump o/k, then it could be a control module fault. if this were the case, then it would probably be wiser to purchase a new washer.
Hope this is of some help to you.
Posted on Jan 16, 2010
blueextc3221
blueextc3221
  • 15935 Answers
SOURCE: I have a hoover vhd8142 washing machine that stops mid cycle
It appears your timer/main controller/CCU has failed in this instance.
For replacement parts - head on over to PartSelect.com or RepairClinic.com and enter in your full model number for a full parts listing.
I recommend both sites because ...
FixYa has no affiliation with either site - I have been using and recommending them for years - trouble free.
PartSelect has a great schematic database for locating the part on your unit and great "testimonials" for each part that often times includes HOW-TO information.
RepairClinic has pictures of each part they sell and also a great how-to and troubleshooting for basic repairs.
If your unit has never been serviced - there should still be an original service manual enclosed in plastic taped to the inside of the shell.
In the service manual are Error codes, maintenance procedures, and troubleshooting steps you can follow.
Anything too complicated or beyond your scope should be handled by a professional.
If you think you want to tackle the repair - and have gotten stuck on a step - reply to your question and I will be glad to help you out.
Thanks for using FixYa - a 4 THUMBS rating is appreciated for answering your FREE question $#@!
Posted on Sep 19, 2010
Jan 16, 2010 | Hoover Washing Machines
What Temperature is crease guard. also fast wash on hoover 1300
Nov 20, 2009 | GE S8000E
My hoover optima machine model no. HNF 6127 keeps stopping at the rinse cycle
Check to see if it is on rinse hold or crease care, if it is this will cause it to stop at the rlnses, also ensure that tjhere is cold water at the valve, a faulty cold inlet valve will cause it to stop,as it will be waiting for cold water.
Plz rate my solutioun.
Thanks.
Dec 16, 2008 | Hoover Washing Machines
My hoover optima washing machine model no. HNF 6127 keeps stopping when it gets to the rinse cycle
Make sure it is not on rinse hold or crease care, release if it is, make sure pump is working, and that the cold inlet valve is working., all of these things could prevent it from completing rinse cycle.
Plz rate this solution.
Thanks.
My 5 year old Hoover 500 mb has started to stop mid cycle or not progress through the cycle !
Mate, I just had the same fault with the same model machine. The local machine repair man called me (i'm a sparky) to double check things for him. The macine stopped at the pre wash rinse part of the cycle every load. He replaced the timer with two NEW ones which both had the same fault as the original. We now suspect an inherrent fault in the timer design but as yet dont have an answer.
Aug 10, 2008 | Hoover Washing Machines
Whirlpool AWO3761 stuck mid-cycle
The cycle doesn't advanceWhen the cycle doesn't advance, it's probably the timer or a cold-water supply problem:
  • It's the timer, if your washing machine fills with water and begins agitating, but the timer never advances--or if the washer is in a spin cycle and the timer won't advance. Then you need to replace the timer.
  • It may be a cold-water supply problem, if the washing machine fills with water, agitates, drains, and spins, but then doesn't fill with rinse water. See There's no cold water.
  • Jul 06, 2008 | Whirlpool AWM6100 Front Load Washer
    Hoover AAA160 Front Load Washer Logo
    64 people viewed this question
    Top Hoover Washing Machines Experts
    peter gittos
    peter gittos
    Gerry Harvey
    Gerry Harvey
    Poppa Maddo
    Poppa Maddo
    Are you a Hoover Washing Machine Expert? Answer questions, earn points and help others
