If you want to get a clue you need to post your issue ai a true DIY forum. I can't find most of my repair post in this forum. This forum to me is a "Call In a repair tech forum" for this model and that is OK if you can't do basic DIY repairs. I don't want to put in a direct link to the washer repair forum of my choice so put in your browser this phrase; Appliance Repair Forums > Appliance Repair Talk > Washers > Maytag/Magic Chef/Admiral/Jenn-Air This is a true DIY Appliance repair forum. In the Sticky: Neptune TL Washer FAV6800AWW 5 post down you will find a link to the Service Manual. You absolutely need the Service Manual to DIY issues with the machine. It's not the best SM but will get you started. I also have repair post in that sticky to help with the most common issues with the machine. If you need help open a post in that repair forum and I will try help you through your issue.
Thanks for your post, Daniel!
Based off the information you have provided the cycles inside of your Frigidaire washer will stop at 12 minutes and making a grinding noise. I also see that you receive an E11 error code and that stands for a long fill time. I would recommend checking over the hoses to assure they are installed properly and not restricted. You may have an issue with your drain pump, motor, or water valve. I would recommend performing a reset on your washer and you can do that by disconnecting power from it for at least ten minutes. I hope this information is helpful to you. -Matt
